SOURCE: cant locate engine number for 2002 Chrysler PT cruiser
The engine number is the 8th digit in the VIN which for this should be a B 2.4L.
SOURCE: 2006 pt cruiser touring addtion tail lights went out
try looking at the bulbs first,their is a fuse for each side of the lights ---do the front side lights work ??think this is just a coincidence that they are out and you have just noticed it .
SOURCE: Change the thermostat on 2002 Chrysler PT Cruiser
Hi, i have put together a step by step guide that will help you with this replacement job. Make sure the vehicle is in a cool state before starting this job.
* Drain some coolant into a clean container until the coolant level is below the thermostat housing.
* Remove the upper radiator hose connection from the thermostat housing.
* Loosen the housing bolts and remove the housing.
* Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
* Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
* The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
* When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
* Install the gasket.
* Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
* When the engine has reached operating temperature make sure the thermostat opens.
* You should be able to see coolant circulating within the radiator.
* Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
* If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
NOTE
When a paper gasket is used and the recess is in the thermostat housing, it is a good practice to position the thermostat into the recess and glue the gasket to hold it in place. If it falls out of its groove during installation, the outlet housing can be cracked or a coolant leak will result. Before tightening the water outlet housing, try to rock it back and forth to be sure it is flush. Housings are often cracked during this step.
SOURCE: Need 2002 PT Cruiser Touring Ed. Fuse Box Diagram
There are 2 possibilities. It is on Power distribution Center (mine was there)
or Fuse Block
Here are the photos:
http://www.ptcruiser.fi/ptgalleria/albums/userpics/Power_distripution_center.jpg
http://www.ptcruiser.fi/ptgalleria/albums/userpics/fuse_block.jpg
If you like to fix your fog lights, you must replace malfunction switch. It is a typically PT-Cruiser problem.
SOURCE: my 2002 pt cruiser lost power steering suddenly
check to see if the serpantine belt is still there. It sounds like like it broke. this belt runs all of the accesories on the vehicle including the water pump. So if this happened it probably starting running hot too
