Cats Logo
Question about Cats
I have the self cleaning litter box. It's making a loud clicking noise and not rotating properly. I have taken it apart, cleaned, & reassembled it but it's still doing the same thing
Posted by miranda owens on
Dylan Schmidt
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
First of all make sure you have assembled it correctly and there is no obstructions, if you have the instructions. You can probably contact the company that might send pieces to help repair the litter box.
Posted on Dec 27, 2017
5 Related Answers
jason
  • 905 Answers
SOURCE: I have an electrolux icon
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Posted on Dec 24, 2008
Anonymous
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
Anonymous
  • 291 Answers
SOURCE: loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
jimmy nutron
jimmy nutron
  • 132 Answers
SOURCE: Wont start sounds like it's getting no spark and starter makes noise.
check the compression and timeing it is easy that the during the lay down the coiles and resistor could have shifted just a little and through off the timeing.
Posted on Jun 03, 2009
Anonymous
  • 701 Answers
SOURCE: the water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Posted on Dec 03, 2009
My natures miracle multi cat litter box won't turn on. When I plug it in the light underneath will blink once and then the on off switch doesn't turn on. Anyone know what's happening?
Contact the maker direct. They will know the fault and what needs replacing. It is probably the small stepper motor.
Multi-Cat Self-Cleaning Litter Box ' Nature's Miracle
www.naturesmiracle.com > litter-boxes-and-accessories
Your cat's litter can now be clean all day, every day with the Nature's Miracle Multi-Cat Self-Cleaning Litter Box! Equip with smart-detection motion sensor and removable automatic rake for a convenient cleanup. This litter box automatically scoops itself after every use for a clean, fresh start every time.
Dec 07, 2020 • Cats
2answers
When rake cleans makes loud noise
Open the left side of the box and you'll see a white plastic part covering the hole. Get scissors and cut it out. The metal piece moving the rake was dragging on the plastic and so I cut it out of mine and now it's back to normal !
What litter box cover works for breeze
I MADE MY OWN OUT OF A CARDBOARD BOX FOR MY LITTER MAID SELF CLEANING LITTER BOX AND IT WORKS GREAT. KAT AT [email protected]
If I buy a self-cleaning litter box does that mean that I am off the hook for cleaning?
Sorry to break the news to you but just because you bought a self-cleaning litter box does not mean that you do not need to clean it. While they keep themselves cleaner than other litter boxes, self-cleaning litter boxes still require an amount of sanitary maintenance. They necessitate regular washing and litter replacement. You should also keep an eye out for any waste that the self-cleaning system may have missed.
Aug 14, 2012 • Cats
I would really like my cat to have a clean litter box throughout the day. Do self-cleaning litter boxes really work? If so, this could be a worthwhile investment.
I would recommend you check out the LitterMaid litter box. It has two sensors on either side of the box that detect when a cat uses it. After 10 minutes, a rake automatically comes and scoops clumps of solid and liquid waste into a disposable container at the end of the litter box. Keep in mind that this does not eliminate you cleaning the box.
Aug 14, 2012 • Cats
Where can I buy a self-cleaning litter box for my cat?
Self-cleaning litter boxes are increasing in popularity and are available at most local pet supply stores in your area or online. Here are a few places for you to search and compare.
http://www.littermaid.com/
http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
http://www.litter-robot.com/
Aug 14, 2012 • Cats
How much are self-cleaning litter boxes?
Self-cleaning litter boxes can range from $45.00 - $350.00.
Aug 14, 2012 • Cats
The bobbin on my machine isn't working properly; the top thread doesn't complete a full rotation and the thread keeps breaking. I can't get past a few stitches without creating a jam. I have tried taking...
have you taken the bobbin case out and cleaned it. Its a simple process if you look directly at where the bobbin goes in you will see two latches one on either side of the bobbin case, release those and clean this area and oil it, reassemble and then reload. bobbin thread could be old or if the bobbin was wound on a different machine the tension could be wrong for this machine. when reassembling bobbin case make sure that all parts are seated corectly, also sometimes the actual case that holds the bobbin may need to be replaced, if its an older machine it could be worn.
2helpful
Top Cats Experts
Tom Chichester
sharon perry
sharon perry
Level 1 Expert
Don A
Don A
Are you a Cat Expert? Answer questions, earn points and help others
