20 Most Recent Singer 2250 Tradition Questions & Answers
Sewing machine top tension discs very loose
repairing it yourself, without any training or mechanical skills could be problematic, given that you have already rejected 'new part' as a solution.
3/8/2018 10:16:58 AM • Singer 2250... • Answered on Mar 08, 2018
Broder avec la singer tradition 2250
AUGMENTEZ(LEVEZ) TOUJOURS le pied de presse quand le filetage le fil sup?rieur.
4/26/2017 2:44:57 AM • Singer 2250... • Answered on Apr 26, 2017
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here: http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx Most likely, the screw end on the machine has broken off.
1/2/2017 7:19:15 PM • Singer 2250... • Answered on Jan 02, 2017
Machine fails to operate
Ooh, do not turn the handwheel in reverse...First, make sure your machine has not been set to wind a bobbin. When that is the case, the needle is immobilized during bobbin winding so that you do not accidentally sew over your hand or something else. (Consult page 18 of the owner's manual.)The machine is less than a month old. If there is something seriously wrong, contact the manufacturer. I should still be under warranty.http://www.manualslib.com/manual/364482/Singer-2250.html?page=25#manual..
5/1/2016 3:06:27 PM • Singer 2250... • Answered on May 01, 2016
2answers
Upper thread is not pulling lower thread from bobbin up through sewing hole
increase the needle thread tension up more the tension is correct when the threads meet at the middle of the material being sewn
3/14/2016 6:31:46 PM • Singer 2250... • Answered on Mar 14, 2016
My sewing thread tensioner doesn't work . I need a workshop repair manual to assess what parts are needed to restore use .
There most likely is not a service manual for the machine. They are mostly computerized, so short of replacing the electronics, there's really not much to repair. You might search the internet for the Make + Model + the word "Parts" to see if there is a parts diagram. But then, finding the parts could be challenge too unless you elect to purchase a used non-working machine to use as a donor
2/14/2016 8:18:09 PM • Singer 2250... • Answered on Feb 14, 2016
Will only straight stitch
Can you specify what's the problem exactly? Sounds like there's something wrong with selection dial. Try to clean it. Also, read the user manual for possible answers and troubleshooting: Singer tradition 2250 manual
12/22/2015 7:54:28 PM • Singer 2250... • Answered on Dec 22, 2015
My needle is stuck in the bobbing case of my sewing machine, it will bend and break if i force it up.
From the pictures I've seen, it looks like you should be able to move the two black levers on either side of the bobbin case and remove the shuttle. With the shuttle out of the way, the bobbin case should be released from the needle. (I've had to do this with my own machines at times.) If the needle is hanging up in the bobbin, it is likely that the machine is out of time (the needle is not penetrating the bobbin area at the correct time). (Verify that you are using the right needles for your machine--some needles are longer and could cause it to hang up in the machine. And then check to make sure you are installing the needle with the flat side facing the correct direction.) You could try to take it for service, however, the cost may not be justifiable vs purchasing a new machine. Perhaps talking to some sewing repair shops will give you an idea of the cost to repair. ...
12/1/2015 4:10:02 AM • Singer 2250... • Answered on Dec 01, 2015
Motor & belt turn, but the needle stops when it encounters normal cloth. Drive belt is NOT broken & the machine has hardly been used. Sews OK when turning the wheel by hand.
the drive belt is normally a cog type belt inside the head of the machine I would be looking in that area and at the belt or at the tension of that belt may be a service technician would be able to correctly adjust and fix the problem
7/23/2015 3:01:27 AM • Singer 2250... • Answered on Jul 23, 2015
3answers
Take-up lever not pulling from spool
Owner's manual trouble shooting "usually" quite clear. No owner's manual? try manualslib.com
6/14/2015 5:35:03 PM • Singer 2250... • Answered on Jun 14, 2015
3answers
The needle has got stuck and does not come out when hand wheel knob is turned counter clockwise
You probably have a Bird's Nest, as they call it, under the needle plate.
  • You need to release the needle from the machine
  • Pull your work up and about so you can access the screws
  • Remove the needle plate
  • Carefully cut the tangle of threads around the needle with a small scissors or scalpel
Make certain you have turned the machine off first! I had this issue with all sorts of sewing machines when I was a Workshop Technician at High School. Students were often in tears when they were sewing something special for an exam!
4/1/2015 2:25:15 AM • Singer 2250... • Answered on Apr 01, 2015
How can I get a manual for this machine?
See link below: Instruction Manuals
3/19/2015 12:59:58 PM • Singer 2250... • Answered on Mar 19, 2015
2answers
The needle has got stuck and does not come up when the handwheel is turned counter clockwise.
I would take it to the Sewing Shop. You've probably damaged whatever the needle has wedged itself into ...plus the needle and maybe the mechanism that drives the needle up and down.
3/16/2015 9:10:53 AM • Singer 2250... • Answered on Mar 16, 2015
0answers
How do I fix it when the bobbin thread won't rise?
Make sure that your needle is ALL THE WAY up in the needle clamp and the flat side of the needle is away from you.towards the back. Review the steps for inserting a bobbin in the bobbin case and raising the thread in your user's manual; if you don't have it, you can download it free at the Singer Sewing Machine site. If you have done these things and you still can't get the thread to come up, then your timing has gone out of synchronization, and you will need to get a technician to reset it for you. If you cannot find a sewing machine technician willing to adjust a Singer, Sears supports all brands of sewing machine.
11/29/2014 4:43:29 PM • Singer 2250... • Answered on Nov 29, 2014
How i use twin needel
Although your machine does come with a second spool pin to allow two spools of thread, it does not come with a button or setting for a twin needle. You can probably put one on, but I must caution you that you can only straight stitch on it, because if you try even a narrow zigzag, its likely that one of the two needles will hit the plate and break, and they are expensive. If you want to try it, I can tell you that you need to buy a twin needle--preferably one with the two needles close together. Put one spool in its regular pin, and the other on the extra spool pin, and thread both threads exactly the same, and at the same time. You will not be able t use a needle threader--you will have to thread them by hand.
11/29/2014 4:54:33 AM • Singer 2250... • Answered on Nov 29, 2014
2answers
Singer 2250 starts at very high speed.
replace the pedal
9/15/2014 1:49:54 AM • Singer 2250... • Answered on Sep 15, 2014
Singer 2250 Tradition Logo
128 questions posted
Top Singer Sewing Machines Experts
David Shaub
dannydoesita
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
needle stuck in bobbing case sewing
  • Sewing Machines
