Exercise & Fitness Logo
r
rhonda jenkins Posted on Jan 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the calorie pulse and distance counter on my gazelle edge thanks
Electro Med Services
Level 3:
  • Master 6,694 Answers
  • Posted on Jan 07, 2017
Master
Level 3:
Answers
6694
Questions
Helped
1872633
Points
21433
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Tony Little Gazelle Power Plus Glider Exercise. The display lights up but no counting, distance or time.
If the display on your Tony Little Gazelle Power Plus Glider Exercise machine lights up but doesn't show any counting, distance, or time information, there could be a few potential causes for this issue. Here are some troubleshooting steps you can take:
  1. Check Battery or Power Source: Ensure that the machine has a sufficient power source. If your Gazelle Power Plus Glider uses batteries, make sure they are fresh and properly inserted. If the machine is powered by an AC adapter, ensure it is securely connected to a working power outlet.
  2. Check Display Connections: Verify that the display module is properly connected to the machine. Inspect the cables or connectors for any signs of damage or loose connections. If necessary, unplug and reconnect the display module to ensure a secure connection.
  3. Reset the Machine: Try resetting the machine to its default settings. Depending on the model, this can be done by turning off the machine, unplugging it from the power source, waiting for a few minutes, and then plugging it back in. Refer to the user manual for specific instructions on resetting your Gazelle Power Plus Glider.
  4. Clean the Contacts: Over time, dirt, dust, or corrosion can accumulate on the electrical contacts. Use a soft cloth or cotton swab dipped in rubbing alcohol to clean the contacts on the display module and the corresponding contacts on the machine. Ensure that they are dry before reconnecting.
  5. Contact Customer Support: If the above steps do not resolve the issue, it may be best to contact the customer support of Tony Little or the manufacturer of the Gazelle Power Plus Glider. They will have specific troubleshooting advice and can guide you through any additional steps or recommend further solutions.
When contacting customer support, provide them with detailed information about the issue, including the model and any relevant serial numbers. They may be able to provide specific solutions or arrange for repairs or replacement parts if necessary.
It's worth noting that the steps provided are general guidelines, and the specific troubleshooting process for your Gazelle Power Plus Glider may vary. Always refer to the user manual or contact the manufacturer's customer support for model-specific instructions and recommendations.
Need gazelle edge spare parts
If your machine is not under warranty or you have questions about a replacement part, contact Fitness Quest customer support at 1-800-321-9236 (old number, latest number I find is 1 800 519 8061 in 2017). You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time, as of March 2011. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken. [email protected]
How to set the programs, distance, pulse, time and calories.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
More information is needed in order to help with your question. Manufacturer, model and serial number would help.
7helpful
3answers
1helpful
2answers
York 2750 treadmill: How do I reset distance display? regards
Does anyone know where I can buy a replacement earlip pulse monitor for York 2750 treadmill?
I can not get the speed, distance, or calorie numbers to come up they are showing 0.00 on them and the pulse rate is working I have a DX15. I have replace the batteries and still only showing the numbers...
hi
open the hood and check the speed sensor i think it is unconnected or to far from magnet
as speed sensor does not feel the speed console does not know if treadmill running or not
1helpful
2answers
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
