Bar Code 290100376546 TB-358 TEAC I tried uninstalling the device and searching for drivers on google but i couldnt find anything please help me and i cant insert the CD that came with it in it ;(
SOURCE: asus crw-5232ax usb device
Normaly the lens has such low life that we think the drives are dead. try to clean it with a good quality CD LENS CLEANING KIT. If there is nothing new, means that the problem was cause by dust on previous cd's, even me I never care about loosing time cleaning a cd when want to see or play it, then this is what can happens to all of us.
The drivers are to the drive be knowed and easily acessed by the Operating System.
SOURCE: Vista Cannot locate the Drivers for this device
Hi
That's the problem with vista... it's still young they are still developing too many drivers needed to support new and old products.
But try this link it should help you a lot...<Driver Download> and post me back the results, it's a downloader of drivers developed from Vista....
I'll wait...
SOURCE: Missing DVD driver
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
SOURCE: Code 39 ?
try this
loadTOCNode(3, 'resolution');
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1.
In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2.
Expand SYSTEM, and then expand CurrentControlSet.
3.
Expand Control, and then expand Class.
4.
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5.
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6.
On the Edit menu, click Delete.
7.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
1.
2.
3.
4.
5.
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
6.
7.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8.
Exit Registry Editor.
Step 4: Restart the computer
If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
SOURCE: DVDRW DVR -K17B all of a sudden can't load driver
At the HP chat center i've got this solution ant it worked for me. good luck for those with the same problem.
Normal
0
21
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Tabla normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Deleting UpperFilter and LowerFilter Registry Keys
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318}
key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click
Save. It is better to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters
(found in right window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion,
click Yes.
NOTE: If this data type is missing, continue to the
next method.
13. Click the REG_MULTI_SZ data type LowerFilters (found
in right window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion,
click Yes.
15. Quit the Registry Editor and restart the computer.
