2007 Ford Fusion I4 SEL Sedan Logo
Jenny Webb Posted on Sep 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the road between Orange and Parkes closed due to flooding?
Terry Hair
Level 3:
  • Ford Master 4,134 Answers
  • Posted on Sep 07, 2016
Terry Hair
Ford Master
Level 3:
Answers
4134
Questions
Helped
1092172
Points
16804
Are you kidding? This website is on the WORLD WIDE WEB! Anyone, anywhere in the world can see your question. My question to you is:
"How in the WORLD am I to know where you are in the world to even begin to answer that question?!?!?!"
FYI - I am in the USA in Central Virginia - bet you aren't!
Testimonial: "Wasn't aware this was world wide."
1helpful
What should I do with convertible & windows not working during flooded on heavy rain?
check fuses and relays but wheres theirs smoke usually means shorted out some circuits or motor access the motor and mechanics where smoke came from motor and electronics probably under water
Why wont my car idle after it warms up it runs good while going down the road but when you come to a stop it stalls out why is this
If your car uses an automatic choke. It could be that the choke is stuck in the closed position. There by flooding your car. Also check your fuel filter, electronic idling.
Are any roads to Gooloogong, n.s.w. closed because of flooding?
call the police or ses and get the open roads information
Can you tell me if the road from narromine to dubbo is closed
All unsealed roads within Narromine Shire Now CLOSED ALL VEHICLES . ESSENTIAL SERVICE VEHICLES ARE EXEMPT. ROADS REMAIN CLOSED Gainsborough Rd Remains Closed Ellengerah Rd Remains Closed Tomkins Rd Remains Closed Pineview Rd Remains Closed Tyrie North Rd Remains Closed Jamea Rd Remains Closed Richardsons Rd Remains Closed Derribong Rd Remains Closed Belmont Rd Remains Closed Dappo Rd Remains Closed Belowrie Rd at the Momo Rd intersection Remains Closed Momo Rd Remains Closed MR354 The Mcgrane Way NOW CLOSED in both Narromine Shire and Parkes Shire.
Water alarm keeps popping up
Coolant light keeps coming on - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > 3 Series / 4 Series > E46 (1999 - 2006)
Jan 12, 2011 - 21 posts - ‎9 authors
Coolant light keeps coming on E46 (1999 - 2006) ... stick was where it was saying it should be in the manual (poking up just above the rim). ... Perhaps your coolant levelsensor is on the fritz. ... Lots of roads, including major highways, are still closed due towater or sludge and rubbish left over from flooding. Has your pre-LCI F30 been reliable so far?
Aug 17, 2015
"Power Window Anti-Trap Function".
May 25, 2012
02 745i - Hood open warning light (CLOSED)
Apr 16, 2009
More results from www.bimmerfest.com
2answers
Injector sprays too much fuel after starting. Engine floods out
Suspect (potentially) either a stuck injector, or a failed/failing fuel pressure regulator. One sign of a failed fuel pressure regulator can be gas in the oil. (I suffered that side effect, along with bogging, and black smoke rich running, worsening as warmed up, turned out to be fuel pressure regulator). If the injector is loose in the throttle body, or has bad o-rings, can also cause some wonky behavior. Good luck.
Is it possible to flush the coolant system and could this had happened due to the car using the orange antifreeze and when I bought more at auto zone I told the guy what I needed and ask was this orange he...
Orange antifreeze is extended use antifreeze and usually can remain in a vehicle 4-5 years before flushing. Dexcool which is made by gm had a problem with coolant gumming up before the 4th year. Many people flushed it out and put regular green in. But then you must flush it out more often. That problem has sense been rectified. If you did not correctly bleed the air from the system before closing it up , that can cause over heating and possible knocking . If it wasn't doing it before the addition.. Have the system flushed and only use the orange that it came with ...Prestone orange is nothing but gm specified dexcool and works ok.
2helpful
Car ships replaced wires plugs o2 sencer sometimes acts like it is flooding run fine on open road.
If it acts like it is flooding while idling, but it runs fine on the road, it could be running too rich and flooding it out due to leaking injectors, bad fuel pressure regulator, or excessive fuel pressure.
I would start by replacing the Fuel Pressure Regulator since it doesn't cost as much as the injectors.
Check your fuel pressure using a Fuel Pressure Check Gauge to see if the fuel pressure regulator is maintaining the proper pressure.
Vacuum is attached to the Fuel Pressure Regulator to control system pressure. When the fuel pressure regulator is not functioning properly it causes the fuel pressure to be above normal operating pressure. This condition causes excess fuel to be injected causing a rich mixture that produces black smoke.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1995 nissan pulsar wont run properly
What your smelling fuel for is the fact that once you start it your flooding the **** out of it.. your fuel relese valve needs to be closed up a bit, your intake for fuel is to high basically, this can and will happen due to racing, vibration, or just over time. Its one of those problems that occurs now and then, it is a simple fix!!
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
