SOURCE: Suspension
That's known as negative camber (positive camber would be if the top of the tire were leaning outward). This should be able to be fixed with an alignment as long as the suspension isn't damaged (ie, a bent control arm due to an accident or a hard hit on a curb, pothole, etc).
SOURCE: 2004 Chevy Malibu Classic needs cosmetic body work
varies by location and damage, would need pictures ect, body shops give free estimates take to 3-4 and see what they say, anywhere from $1,000 up likely
SOURCE: My 95 honda accord has a rear alignment problem.
Yes you should get it align, in the long run it will cost less than new tires.
SOURCE: tire pressure
Chris is wrong, the max pressure on the tire is there to tell you if this tire will work on your car. If the max pressure for the tire is lower than what your car says, you need new tires. Otherwise, use the tire pressure shown on the sticker on your car.
Sorry I mean tire is turn inward...
