try to run Maintenance from windows control panel, also open all compartments on teh printer and look to see if there is a fragment of paper stuck there.
it seems that the head cannot move from its initial position to the paper margin position. check for any objects in the paper path. Put a paper (not more than 220 gsm) in the paper tray and press eject button. Push paper to go inside the printer. It will come out with the paper or object in the path. If it did not give solution call the service call centre.
if printer not show any error message (and in ready mode) then place a art sheet in tray and print a page attend paper forcefully by hand to remove lost paper with this art sheet
if printer show any error message like paper jam try to remove with open the front door
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
printer back on.
alternative :
Load
