Question about HP LaserJet 4350 Printer
My hp laserjet 4350 shows error 13.01.00 paper jam in tray 2 and always print one page
When issue print command it print only one page without printing the rest of the pages
Posted by minoco200420 on
  • minoco200420
    minoco200420 Mar 24, 2013
    my hp laserjet 4350 shows error 13.01.00 paper jam in tray 2 and always print one page
Sanjay Vishwakarma
    New Friend:
Solenoid issue
Posted on Mar 13, 2018
L Pfaff
    Top Expert:
  • HP Master
  • 11,573 Answers
Clean the feed rollers.
Posted on Jun 26, 2016
Mohamed Hejazi
    Filmmaker:
    Uploaded 5 video answers.
  • HP Expert
  • 196 Answers
Some 4250,4350,4345 printers showing 13.01.00 paper jam while printing from tray2 .
Tray lifting is okay.
1.all paper feeding rollers replaced,
2.replaced paper feed mechanisam
3.replaced tray2
still same.
Some times open and close tray 2 printer starts printing one page and show the same error.
Posted on Mar 24, 2013
5 Related Answers
Muggs01
Muggs01
  • 72 Answers
SOURCE: HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Posted on Jan 16, 2009
checkitright
CheckitRight
  • 1363 Answers
SOURCE: HP color laser jet 2600n wont feed paper
found problem ??
Posted on Sep 08, 2008
Anonymous
  • 115 Answers
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Posted on Oct 23, 2008
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
Evildice
Vasil Hristov
  • 222 Answers
SOURCE: i have an hp 4200n that picks up an extra blank page
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Posted on Oct 15, 2009
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
HP D7260 will not print two sided
This model printer does not have a duplex unit and therefore cannot print double sided printing automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jun 13, 2012 | HP Photosmart D7260 Printer
1650en produces syntax error when printing
Have the DRAM and SRAM cleared. Will lose a lot of settings so make sure they are written down.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 21, 2012 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Brother printer taking too long to eject a printout
I'm not sure I understand your question. It sounds to me like the printer is working properly. An inkjet will spit a text only page out faster than a page with graphic data on it.
Ink Jets print the images in a "Swath" pattern. This is what gives the page the step motion on exiting a printer.
Now laser printers, since they are intelligent printers, will build an image and then transfer the image, fuse the image and eject the page in one smooth operation.
But lasers would require a "Print Page" command from the datastream to force the page ejection or trying to print outside of the no print area on the page.
For example a PCL 5e datastream would issue a hex 0x0C command to eject the page.
PostScript wouold issue a "Showpage" command.
Don
Jan 29, 2010 | Brother MFC 4650 All-In-One Laser Printer
CAN PRINT PAGE FIVE WITHOUT STARTING FROM PAGE 1
yes when you give print command that time you choose the option by going in printer properties.and choose the desire page.
Jan 25, 2010 | HP LaserJet 1320 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Print Failure
Try printing a different application or file, try printing a test page form the printer itself does it print an internal test page? then the file has a problem.
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 4350 Printer Logo
1,379 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
