Yamaha Generator Ef5000 Ef6000 Intake Gasket Carburator Ef 5000 6000 Logo
John Jennings Posted on Jun 24, 2016
Hi I have a ef6000 yamaha generator. The only No I can find on the engine is 7ky 359cm3. I need a new carburetor and can only find one for mz engines. Are they the same. Or how do I find engine No?
Myron Scharkey
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on May 05, 2017
Myron Scharkey
Contributor
Level 1:
New Friend:
Answers
25
Questions
Helped
8280
Points
57
Babbits Yamaha partshouse on the internet, I would start there.
1 Related Answer
Anonymous
  • 72 Answers
  • Posted on Sep 07, 2008
SOURCE: conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
1helpful
2answers
Engine on generator starts but hunts all the time so i cant check output on generator
Governor hunting is almost always a carburetor issue. Likely air leak (vacuum) between carburetor and engine intake. Make sure carburetor has not come loose. If carb/gasket mounting ok, suggest drain and replace fuel. Drain and clean the carburetor bowl as well.
If still hunting, likely the carburetor has fouled. You can try a fuel treatment e.g.1oz/gal seafoam and see if problem clears otherwise carb clean/rebuild or replace.
1helpful
2answers
I have a Yamaha EF1000is and it surges. I have cleaned and checked all interior jets float needle fuel lines muffler and it still surges
Make sure there are no vacuum leaks on the engine manifold side of carburetor. There are 3 o 4 pieces on the engine side so inspect well.
If no leaks on engine manifold side then likely there's a blockage somewhere in the carburetor high speed circuit. Most economical solution is chinese knock-off for ~$20 US delivered.
If you can't find a cheap replacement then you'll need to do a deeper clean of carburetor by removing welch plugs and submerge in carb cleaner. You will need new welch plugs (kit) and likely kit will cost more than a knock-off carb.
Before tearing down carb, you could try Seafoam fuel treatment... probably less the 50:50 chance it will clear.
2answers
My 4000 watt predator generator starts ok then starts racing
Loose carburetor mount at engine intake port and/or carburetor fouling. Check the carburetor mounting adapter (gasket) is intact and all carburetor mounting bolts at proper torque.
Economy switch not working on ef6000
start engine with no load first and warm it up , they run high rpm about 2400 or more with no load..
I need a new robin subaru thottle body r1100
I believe this generator uses a carburetor.
Try calling Jack's Small Engines during their business hours; I don't see a carburetor listed separately and it may be very expensive.
Robin Subaru R1100 Generator Parts Diagrams
You may be able to just clean the carburetor you have and save a lot. The video isn't the exact engine but it is close.
Yamaha 5200d it starts and runs 2/3 minutes and shuts down oil is full low oil lite does not light up carb is clean
This generator is equipped with an auto choke. What is likely occurring is as the engine warms up the choke is returning to the normal choke off run position leaning the mixture two lean to maintain operation of the motor.
This is occurring because the residual fuel that was left in the carburetor has evaporated and the gum residue is reducing the fuel flow through the carburetor. When the choke is applied the mixture is rich enough to support running and as the choke returns on its own to the run position the mixture leans out and the generator stalls..
Override the choke when the engine is starting to falter to confirm the problem. Continuing to attempt to run the engine possibly adding a carburetor cleaner additive to the gas will likely return the unit to normal operation.
If attempting to enrich the mixture by applying choke when the engine begins to falter does not work then a fuel flow problem to the carburetor may be the root cause. I would look for a plugged fuel filter or restricted fuel flow from the tank to the carburetor. What is happening is when the unit is at rest the carburetor is filling with gas and as it is running because of a restricted fuel flow the level lowers in the carburetor bowl resulting in a mixture to lean to run.
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
