Question about Yamaha Electrical Supplies
Why does my Yamaha EF1000 Generator leak gas out of the gas tank vent hose which comes out of the fuel petcock (on/off valve)? It does it when its not running but and even a few moments after it has ran, and also when it is running sometimes it will leak but just a little bit? the carb is clean and vent/overflow line from carb is perfect and not restricted and never leaks, so the carb is not overflowing!, and the engine always starts and runs great! but i keep loosing fuel? But a note, after it sits not running and/or after it has ran, you can remove gas cap and hear pressure release! Any answers would be appreciated!, Thanx A Million
woobie dog
    President:
  • 1,273 Answers
Check that the vent hole in the cap isn't obstructed.
--W/D--
Posted on Jan 18, 2011
  • 2 more comments
  • Anonymous Jan 18, 2011
    The Tank does not vent through the cap, the tank vent line is plugged into the side of the petcock fuel valve somehow!, any other idea's? Thanx A Million for the reply, as that was my first thought to the answer to the problem!
  • woobie dog
    woobie dog Jan 18, 2011
    Some Yamaha products require a vacuum to keep the fuel diaphragm in the petcock open, allowing fuel to flow. This, however is not on the tank side of the petcock, indicating to me that there shouldn't be a vacuum on the tank. Try running the genset with the cap cracked enough to allow the entry of air to the tank. If the problem corrects, look for a means of venting the petrol tank. If the problem persists, consult your dealer, and see if your petcock requires a diaphragm type system as described above. If so, you may need to replace the diaphragm.
    --W/D--
    Your fast on the draw with the answers, i like that and thank you, However the petcock on the tank does not use a diaphragm setup, which i know what you are refering to from my motorcycle experiance, But it uses just a basic type on/off petcock with the little rubber valve inside and normal cover, control lever with o-ring with the two screws and that bolts to the bottom of the fuel tank but does have a vent hose running from it along with the fuel line on the opposite side, i am starting to think it is that rubber valve in the petcock that rotates when the petcock lever is rotated from off to on that is coming apart or has hardened and not opening the vent part or something when valve in petcock is closed which is activated by the control slide lever which is three position off/run/choke and when the control slide lever is in the off position it moves a lever and turns the petckock to the off position shutting off fuel, on run and choke it turns the petcock on allowing fuel flow! but to me shouldnt the tank be vented regardless of fuel valve position? if you look up the parts diagram on yamaha-motors website you can see the petcock and parts, i guess it looks like i will just have to take it all apart and see whats going on! What do you think?
  • woobie dog
    Yes, I agree that there should be a tank vent, and that it is plugged. Did you try running the engine with the tank cap cracked? You may have to disassemble the petcock and check to see if there is internal damage. If so, the repair costs will be minor.
    --W/D--
1995 Yamaha TZR 250 fuel tank leak
Hi, Martyn and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1995 Yamaha TZR 250 fuel tank leak Google Search
Fixing motorcycle gas tank leak Liquid Gasket Application
Yamaha TZR250 1987 Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Jun 28, 2018 | 1995 Yamaha TZR 250 R
1980 Yamaha DT 175 carburetor leaking
Hi, James and the usual suspects are:
DT 175 Gas Leak HELP
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Yamaha DT100 DT 100 Motorcycle Complete Workshop Service Repair Manual... $20
http://mybikemanuals.com/yamaha/yamaha-dt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 15, 2018 | Yamaha Motorcycles
1996 Yamaha XV 535 Virago DX not getting gas to carburetor
Hi, Anonymous always check the fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing*
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn*
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working*
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
* If equipped or applicable.
ViragoTechForum com
6 YAMAHA VIRAGO FUEL LINE REMOVAL
Yamaha XV535 Owners Workshop Manual
OEM parts for Yamaha
YAMAHA XV535 Owner Manual
Oct 04, 2017 | 1996 Yamaha XV 535 Virago DX
1981 Yamaha XJ 650 not getting gas to engine
Hi, Terry I would do a compression check first and always check the fuel flow second to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Total Motorcycle Forums
Carburetor Issues on my 1982 xj650
Yamaha XJ650 1980 1984 Manuals service manual not owners
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Oct 03, 2017 | 1981 Yamaha XJ 650
Cant figure out which hoses hook to which valve lines on a 1986 yamaha riva moped scooter fuel petcock
Large line is fuel, from tank to petcock. Large line from petcock to Carb. small line is vacumn from intake manifold to petcock (small spigot). suck on this line & make sure Gas comes through Large line to Carb.
Dec 16, 2013 | 1985 Yamaha XJ 700 X Maxim
2006 Yamaha TTR 125E - carb not getting gas
Hi, Kevin always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Dirt Rider Magazine
TTR 125 won start need help TTR
Yamaha TT R125EW Owner Service Manual
Yamaha TT R125E Owner Manual
Jun 13, 2013 | 2006 Yamaha TTR 125 E
Any thoughts on 2006 Virago 250 with gas leaking out of right exhaust pipe?
Hi, Andrew and the usual suspects are:
Gas coming out of exhaust help
Fule Dumping out of exhaust will not start
Yamaha VIRAGO XV250S Owner Manual
Yamaha XV250G Supplementary Service Manual
May 05, 2013 | 2006 Yamaha Virago 250
My 2005 yamaha TTR 125 will not let gas flow into the carb bowl, you can pour gas into it and it starts right up, thanks!
Your float in the bottom of the carb is likely stuck in the up position. The float attaches to a valve that shuts off fuel flow when level is just right. Can you see the little screw at the bottom of the bowl? Do you see the little overflow hose below that? Get a plastic soda bottle, put the outlet of the tiny hose into it. unscrew that little screw a few turns. Do you see fuel coming out? No? then take the back end of a screw driver and tap the bowl of your carb sharply 5 or 6 times. (Make sure the fuel pet **** under the tank is turned on. If you do not see fuel going into your bottle in a minute, shut off fuel at the tank. Screw the bowl drain back in. Remove the larger incoming fuel line that goes from tank to carb and put it into the bottle. Now you will open the petcock a little bit slowly. If you never see fuel come out of the tank, thru that hose, then your screens on the petcock may be clogged. Shut off fuel , Remove the cap on your fuel tank. blow into the line while slowly opening the petcock valve. Hear air bubbling in the tank yet? If you do, shut off valve, remove air pressure from line, point it back into the bottle and reopen the valve. If none of this works, then you need a new petcock valve.
Nov 29, 2010 | 2004 Yamaha TT-R 125 L
Gas is pouring out of the overflow hose between the carbs on my 96 Royal star. It has never done this before. when the key is turned on the pumps clicks a few times and gas comes pouring out and when I...
Hi, Osierj and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Star Classic leaks fuel behind the air cleaner
Help Gas Leaking Out of Yamaha Royal Star
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
YAMAHA XVZ1300A Owner Manual
Oct 17, 2010 | 2007 Yamaha Royal Star Tour Deluxe
What steps do I take to get a Yamaha EF1000 gas powered electric generator going again after it has been sitting around for years with gas in the tank? How do I drain the gas from the tank and carburater?...
You can disconnect the fuel line from the carb and drain the gas. It would be even better to then remove the fuel tank. If this is the generator with the large plastic tank, quite often the rubber gromet in the bottom of the tank with shout off vavle in it will deteriorate into a black gooey mess, and leak. If so that will have to be replaced. Clean inside of tank with fresh gasoline. Remove bowl from carburator and clean throughly. If you know how to work on engines, remove the carburator and clean throughly, notice how all springs and linkage were connected before removeal. Be sure all passage ways in carb are clean. Always use sta-bill in your gas.
Jul 23, 2010 | Yamaha Electrical Supplies
Electrical Supplies Logo
3,379 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
