If your Chefs Mark air fryer is not turning on, there could be a few possible causes. Here are a few things you can check:
- Check the power source: Make sure that the air fryer is properly plugged in and that the outlet is functioning. Try plugging in a different device to the outlet to make sure it is working.
- Check the fuse or circuit breaker: Make sure that the fuse or circuit breaker that the air fryer is connected to has not tripped.
- Check the control panel: Make sure that the control panel is not damaged or malfunctioning. If the control panel is not functioning properly, it may prevent the air fryer from turning on.
- Check the thermostat: Make sure that the thermostat is not faulty. If the thermostat is faulty, it may prevent the air fryer from turning on.
- Check the timer: Make sure that the timer is not set to a time in the past.
- Check the power cord: Make sure that the power cord is not damaged or frayed. A damaged power cord can prevent the air fryer from turning on.
If none of these steps resolves the issue, I would recommend contacting the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or may recommend a qualified technician to repair the air fryer.
