Microwave Ovens Logo
W
WOOSYE BHAVNA Posted on May 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY LG MICROWAVE CONVECTION OVEN MOD: MC-7847BS TOUCH PAD IS NOT WORKING AND ONLY INDICATING A ZERO
THE TOUCH IS NOT FUNCTIONING AND INDICATING A ZERO ON THE TIMER
Electro Med Services
Level 3:
  • LG Master 6,694 Answers
  • Posted on May 21, 2016
LG Master
Level 3:
Answers
6694
Questions
Helped
1872628
Points
21433
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 08, 2008
SOURCE: LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 20, 2008
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
A
Anonymous
  • Posted on May 27, 2008
SOURCE: Panasonic Microwave Combi Oven - convection heating not working on timer
fu*k u
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 23, 2008
SOURCE: instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Anonymous
  • 54 Answers
  • Posted on Apr 24, 2009
SOURCE: I jus brought an LG microwave oven (MODEL
E-02 on the LED display.
That usually indicates a keyboard error...not a good thing...take it back and get a new one.
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
How to use mc what is the indication of mc , grill, and convection and which type of utensils can be used
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Touch pad doesn't work LMVM1945SB Microwave
that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
Microwave has stopped working and now I receive a flashing No10 in a square and a flashing No 1 in a square.The rest of the oven works, the convection side, What now....help!?
My wife cannot wait forever for me to solve the problem with our Microwave....so I nhad to bite the bullet and take it in to LG for repairs.
Thanks for the good site
1helpful
14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Lost instruction manual
Hi - You can download the manual from the link below:
MC-924JLR
Please update the question & let us know if the information given was useful to you - Good Luck!
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
