Model mj23 2009 mfg date
SOURCE: PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
SOURCE: coating is peeling off my microwavww handle????
How nice of them!
Often it is caused by the use of hand cremes affecting and tarnishing the metal coating or the plastic pigments.Many items suffer from handremeitis
including the letters on keyboards car door handles, AC knobs etc etc.
Unfortunately it is the way of life that is associatedkin care and vanity.
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
