Press and hold Clock/Timer for 3 seconds. Will show 12Hr. If Want 24 hour clock, push again. Enter the time and push Clock/Timer again. Finally found this manual so thought I would share. https://images.homedepot-static.com/catalog/pdfimages/8b/8b34816c-f8e0-4a97-956c-e0b2563a540e.pdf
I'll bet it is in the manual
Which would be great had one actually been included
To set the time display, the steps usually are to first turn off the microwave oven completely. Then power it on. Touch the "Clock" or "set time" pad and key in the current time. Press the set pad to lock the time.
or maybe this
Press the "Clock" button once, then the correct number buttons to set the desired 12-hour time. Press "Clock" again to confirm. If you want to use 24-hour time, press the "Clock" button twice before inputting your numbers and pressing "Clock" again
On our model, you have to press START after entering the time, not CLOCK a second time.
SOURCE: Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
SOURCE: can't set the Clock on microwave
One of these combinations may work:
CLOCK > 1
> 2 > 3 > CLOCK
CLOCK > 1
> 2 > 3 > START
CLOCK > CLEAR
> 1 > 2 > 3 > CLOCK
CLOCK > CLEAR
> 1 > 2 > 3 > START
Otherwise, I would contact the dealer you bought it form to see if they have a number for Cascade.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important
protection for the magnetron.
And always keep it clean according to your manual's instructions.
We're
