ZEEPAD 7DRK Dual Core 4.2 Blue Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 BLU Logo
Tony Young Posted on Feb 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clutch burnt out
@ 16,000 kms
Terry Hair
Level 3:
  • ZEEPAD Master 4,134 Answers
  • Posted on Feb 11, 2016
Terry Hair
ZEEPAD Master
Level 3:
Answers
4134
Questions
Helped
1092155
Points
16804
If you are under 25 years of age, I have a pretty good idea why that is......if not, and you are not a completely incompetent stick shift driver, then I would assume that there was something defective in the clutch or it wasn't properly installed. If this is in a new car, if there is a defective materials issue, warranty should cover it regardless of the fact that it is a clutch. But it may be hard to prove as defective.
Lenovo tablet screen went black like battery was dead does not work any more just like battery was dead
you might need to replace the backlight on the screen, the CCFL has burnt up like normal fluorescent light does after a few years of continuous use.
Lenovo Tablet Repair
I have a NextBook Ares 8 Tablet. Why does it take 12+ hours to recharge?
(this is all i could find on the internet so this is not to say it will help you but try it and see what happens).........PRess the power button and the volume down button at the same time and hold until the unit restarts... it resets the charging cycle and the note will charge reasonably quick from then on... I do this on occasion when my battery seems to charge slow.
plus some people are saying get a new charger.
Rca tablet got fried by microwaved
Submerge your tablet in a bathtub full of warm water. And let sit for about 5 mins. And then try to charge it. Tt should fix your problem. And future reference, the tablet needs to be wet before u microwave it. Otherwise it jusr fries
Samsung tablet wont charge or come on
Make sure you're using the factory charger (most tablets require 2.1 amps, or 2100mA.) If that isn't the problem, you'll need to get someone to look at (or test) the battery.
If you see bulging, or smell burnt plastic, you'll need a professional to look at it.
1helpful
How do I fix no color on screen for android 4.2?
Color lights have burnt out. Replace the screen or get a new tablet. I reccomend an iPad because Android Tablets are weak.
Backlight lenovo ideapad k3 lynx seems burnt out, but will sometimes dim when cooled down
Have you tried resetting it also the fuse or resistor for the backlight might just need replaced
Screen went black
is there any light emitting from the device at all? (turn off light and see if the screen is showing light)
if it is, check your brightness settings on the device
if there is no light it is possible that the backlight burnt out, or that there are settings that need to be adjusted on the device. It is also possible that you downloaded an app that doesnt work properly with your device.
if none of this seems to be whats wrong, more information would be nice:
1) what model of tablet are you using?
2) what version of android OS?
3) what app were you trying to install?
From there you'll be able to get more help if needed.
My lifebook 4215 doesnot display on its screen but can display to an external monitor because the output section of the mb has no small ic like components and a cable jack can I please have a proper...
Call the Fujitsu service 800 number, you may still be under warranty.
It sounds like the inverter has burnt out, take it to a Fujitsu authorized repair shop, your tablet has a security feature that will lock you out if it is opened by an unauthorized repair shop or anyone else for that matter.
They take your tablet security very serious.
Ram failure notice on bootup....what's causing....
Not easy to say what it caused it, but if its bad the problem will be solved whit replacing it.
To be sure you can always run a memtest, download the program version from the site below, burnt it on a cd, reboot from your cd-driver and let memtest check your memorysticks.
http://www.memtest86.com/
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
