The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) has failed.
Possible Causes
- Reversed polarity or mis-wire along with open ground switch(es).
- Communication cable from CCU (MI3) to MCU is damaged.
Procedure for reversed polarity or mis-wire
1. Clear error code.
2. Unplug washer or disconnect power.
3. Check the white wire on the RFI filter to ensure correct polarity.White wire needs to be toward front of washer.
4. Check outlet for correct polarity. To check within washer for polarity at the RFI, white to cabinet ground must be 0 volts.
5. Check that the ground switches of the toe panel and rear panel are correctly closed.
If switches are good ,replace the CCU.
