Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Model uw40t8lw. Why doesn't it turn on?
The TV doesnt turn on
Posted by Lucila Jimenez on
Why my westinghouse uw40t8lw color is messed up? My mom was trying to turn it off and God knows what she did color changed to green.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 07, 2014 | Televison & Video
MY LG 45IN PLASMA TV HAS NO PICTURE AND HAS A STATIC LIKE ON A CHANNEL THAT DOESNT COME IN.MY REMOTE STILL WORKS TO TURN IT ON AND TURN VOL. UP AN DOWN AN CHANNELS BUT NO CHANNELS JUST STATIC 42PQ10-U
check your cable coming in from your provider, it may be loose. if that' s ok then rebout your provider box. if that doesn' t work, check the settings on your tv with the remote that came with your tv.
Sep 30, 2014 | Televison & Video
I have a westinghouse tv VR-6025Z. My Blu-ray will not show because the tv will not go to 1080p. It is only staying in 720p. How can I correct this?
I have tried playing with the settings on my blu ray player and then hooking it up to the tv and it doesnt fix the problem. 1080p/24 is turned off. Here's my story.
For the last 3 months, I have had a constant headache with Westinghouse and Toshiba.. My Toshiba BDX2250 worked fine with my Westinghouse but the blu ray player broke after 7 months so I returned it to get a new one but they didn't have any more of those models and gave me a newer model - BDX2300. That one gave me the start up screen and then went black - doesn't play movies, audio, can't get to the start up screen.. But, it works just FINE with other tvs other than Westinghouse. It worked with my parent's Vizio... Then, I got another one of the same players cuz I thought it was broken and then I realized it just was the tv or the model. So finally they send me another newer model the BDX3300. This one does the SAME thing. I call Westinghouse and they constantly say a level 2 tech will call me back but they've lied constantly. One lady even told me that level 2 techs don't even exist. 10 minutes later, she said she would get me on the phone with a level 2 tech because 2 were standing right next to her (wait, what happened to them not existing?!) and she comes back from putting me on hold and never put me on the phone with them! Now the 3rd person I talk to tells me Westinghouse isn't compatible with Toshiba blu ray but I ask if its all the tvs and she says she doesn't know she doesnt see why it would only be one but I wonder if its cuz this is a black friday tv? But then again, I think Westinghouse just SUCKS and none of them work with toshiba at all cuz they lie to me constantly. They tell me different things EVERY time. I hate Westinghouse and am filling out a complaint to the Better Business Bureau BBB now. This has been a horrible experience and I will always buy the more known, expensive brands from now on!!
May 10, 2012 | Televison & Video
What is the model number of your tv?
Dec 06, 2011 | Televison & Video
It doesnt turn it on . I read that it could be bad capacitors . Is this true ?
This T.V. is less likely that capacitors made it go bad. There is probably a MOSFET that went bad or the H.O.T. (Horizontal Output Transistor.) There could have even been a power outage that caused the main fuse to blow. You never know unless you look inside of a dead T.V. if it doesn't have a blink code.
Jun 07, 2011 | Samsung TXM3281HF 32" TV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Doesnt turn on
Either there is a bad fuse under the cover, or the power supply is shot. THe fuse should be a glass fuse which has a wire inside of it. The wire should extend all away across the fuse. If it doesn't than the fuse is bad. If fuse looks ok, the power supply is probably shot.
Jun 22, 2009 | Directv Plus HDTV Receiver with Integrated...
Hi I'm trying in install Freeview but it doesn';t work. Do I need to have the TV on AV?
Hi.
If your freeview box is not built in to to TV set & it is a seperate stand alone box it must be connected to the TV using scart lead.
Then press AV on tv remote if it doesnt automatically show on TV screen.
http://dysonmanuals.llc.nu/
Chris.
Mar 07, 2008 | Televison & Video
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
240 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
