MY SONY CAMERA GOT WET ITS NOT CAPTURING PICTURES OR NOT RECORDING VIDEOS. EVERY THING IS WORKING BUT THE SCREEN IS NOT DISPLAYING THE IMAGE ITS BLANK. ITS VIEWING PREVIOUSLY TAKEN PICS BUT AFTER ITS WET ITS DISPLAY IS NOT WORKING. WHAT TO DOOO???????? I HAVE KEP IT IN ZIP LOCK IN RICE FOR 1 WEEK BUT THERE IS NO RESULT... WHAT DO I DO?????? MODEL:SONY CYBERSHOT DSC W330 DIGITAL CAMERA WITH 14.1 MEGA PIXELS .
SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
SOURCE: Sony Cybershot DSC-W100 Digital Camera
This does depent on the software you are using to print the images- The data is in the images the computer programs has to find it. What program do you use to print?
SOURCE: blurry pictures
This is the problem of the ZOOM in your camera. Its alignment is disturb by you. Your camera must have fallen down or some one has pressed the ZOOM from front when it was open. The solution is to get repaired at your nearest SONY service center.
there is a problem with your hardware in the set.
The IMAGE IC has got a problem. So change it for the best result.
SOURCE: Sony DSC F717, screen and view finder now show
Please take a look at the symptoms listed here, and see if it's what you're experiencing.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
The cameras capacity to capture motion pictures is disimpressionful. Usually cameras have feature functionalities either as still picture shoot or motion video recorder devices. Cameras may have any once of the mentioned features or both as complementary for videographic requriements. Inspecte the camera for capacity to capture motion picturee. Usually, the lense capacity with pixel capacities are indication of extensive capabilities. An impressionful camera producign disintergral result requries adjusting the lense or pixles buttons prior to photo shut. Also, cameras that least have the pixel capacity requires photo shoots at still motion or at calm climate least onbracting activities. Capture pictures at areas that least have movement caused by human interfernce or windy or suny blurs. Also, capture pictures maybe retored of blurry filming from computer photo video editor programs. Capture the picture or videos to be loaaded on to a computer that allows editting to achieve desired interfaces.
