Typically while I am (trying to) pontificate about how easy new sets are (if you are careful) ... I talk about the big circuit boards.
The fact is... there is a tiny power control board at the edge of your case.
Keeping in mind that 95% of all REMOTE FAILURES are TIRED BATTERIES...
Check those battery contacts... too
(seriously)
That tiny power control board has the all seeing REMOTE receiver on it.
The first thing I would do...
is clean the area at the edge of the case.
Failing that:
Get another Samsung remote (buy it or borrow it)... they ARE NOT that expensive.
Failing that...
I would buy that SAMSUNG <remote> Control circuit board.
Good luck & happy hunting
Re-program the remote control.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Thank you guys for your help., I've ordered a new one. Hope it works!
