Rowenta Master Valet 1550W Upright Garment Steamer w/ Accessories - - Logo
Mark Smith Posted on Sep 13, 2015
Just assembled new steamer and it will not power up. Not even the light comes on.
1helpful
What is wrong with my Eureka enviro steamer?
It is limescale. Basically your steamer takes water and boils it dry and turns it to steam. Any minerals like calcium in your water is left behind as rocks or flakes.
It should be descaled once every couple of years. You can do it fast with a product like CLR, or overnight with white vinegar. Fill it up and leave it, next day, turn it on and get it hot, but not boiling. Turn it off and leave it to cool. Empty and rinse 3 or 4 times.
Where can I get a replacement plastic part?
Try the place that you bought it. They may have the supplier / manufacturer information of where you can get parts from.
Why is there no steam?
Plugged in? Add water? Check the fuse on the power cable.
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
2answers
Home touch ps-250B steamer
Need Water Tank top cap which is brocken
3answers
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Top Rowenta Garment Steamers & Presses Experts
ADMIN Andrew
ADMIN Andrew
john h
Stan Ford
Are you a Rowenta Garment Steamer and Press Expert? Answer questions, earn points and help others
