Question about Royal RY7910 Procision Deluxe Upright Steamer Extractor
Why doesn't cleaner dispense water?
When I depress button on handle, water or soap doesn't come out on the bottom
Posted by Donna Egbert on
Ruben
    New Friend:
  • 20 Answers
Clean the nozzles with a needle
Posted on Aug 27, 2014
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Aug 27, 2014 | Royal RY7910 Procision Deluxe Upright...
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Why are there hard deposits in the boiler of my eurosteam iron?
Tap water contains minerals/chemicals, whether it's from a well, or from a city source. When water is heated to steaming, these minerals, precipitate out of the water and form deposits. Use some vinegar. The mild acid will help loosen the deposits... and from now on use distilled water.
Jun 10, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
Euro steam iron
Seems silly... but is it plugged in to a live outlet? Does it have water?
Sep 30, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Conair Lysol hand held steame
It could be broken but it could also be jammed or clogged by some dirt or water. My first answer would be to get a new one. but if you dont want to throw it away you should take it to a recyling store.i know that is getting rid of it but it is not exactly because you still remember it.
May 25, 2013 | Garment Steamers & Presses
Royal RY7910 Procision Deluxe Upright Steamer Extractor Logo
1,031 people viewed this question
Top Royal Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Royal Garment Steamer and Press Expert? Answer questions, earn points and help others
