Televison & Video Logo
Martin Bastida Posted on Sep 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It blinks 9 lights what does that mean - Televison & Video
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Sep 06, 2015
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723429
Points
23750
Need the model number of the set in order to assist
My Sony 46" big screen projection TV comes on for a few seconds then it stunts off and the standby light blinks 9 times. What does that mean?
Could be 51". Models KP51WS510, WS520, WT520. 9 blinks is power supply. -where power cord goes into back.
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
TV won't turn on, standby light just blinks 9 times
hello, Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
regards
shaun
3helpful
57 "SONY, DOES NOT TURN ON BUT STAND BY LIGHTS BLINKS 9X, THEN STARTS OVER
I dont think your unit has big problem.
1. 9X blinks means 9 VDC supply is shorted either in A or B board.
2. IC708 is faulty in A-board
3.PS701 or PS702 is opened in A-board.
Dont forget to Rate!
Good Luck
Dals123
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
