If
it is lost nothing can be done. You need to flash your mobile at an
authorized service center which will reset the mobile memory and also
all the data inside the mobile will be lost.
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
Look it up in the owners manual. If you have a generic remote and lost the code listing most can be obtained online by going to the manufacturers website. It's also possible that if the remote is not working it is bad and needs replaced. As cheap as they are now that would be the easiest solution. Let me know how you make out.
Moving means that you have to setup the router again. The WEP key has to be setup again. Your old settings were for old location. Could be same settings, but they have to be setup again.
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
There is a little hole on the back of router, push that button inside for 5 sec with a paper clip. That should reset. You will need to setup a password. I usually make mine my phone number. Thats easy to remember and tell guests.
All right. I have some code for you because i just bought an universal remote controle. So, whish king of TV, DVD or electronic devices are you trying to connect? I need to know the brand and what is it (DVD or TV etc...)
Hi jamie,
did you remember the procedure to scan for the codes ? Normally if your TV is not listed on the manual, you can execute the search mode ponting to the TV. As soon as the TV turns on, press the accept key on the remote. I had the sam problem, luckily I remembered the scan procedure. I have 3 different brand of remote controls, all with scan capability but diffeent key strokes.
