PIAA 2003 Chevy Cavalier - All Cavalier models - Xtreme White Bulbs Logo
A
Anonymous Posted on Jun 14, 2015
Why does fuse keep blowing when I turn, turn signal on?
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Jun 17, 2015
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998668
Points
455836
03 s10 turn signal fuse keeps blowing
the turn signal circuits are shorted,,the fuse blowing saved you from a fire.(burning harnesses)
faili on left or right or both and HAZARDS? SORRY 3 fuses to learn that.
USA answers, Chevy S10 only
there are 2turn fuses, I see, in the schematics.
LT-turn and RT-turn, so now you know which side is shorted. just a glance and bingo , side. bad know, cutting work in ;1/2.
but, there is 10amp turn fuse too, that runs the turn flasher module
so 4fuses, turn left and turn, main and haz main.
this is bad.
turn-undefined-undefined-0.jpg any thing in this whole turn system can blow fuse turn main, BLK.
but learning if only one side fails ,is great moment,
if both fails, the problem is this module or the turn swtich is shorted.
1helpful
Signal fuse keeps blowing
Does the fuse blow on both left and right sides,or just blows randomly or as soon as you put the new fuse in?
Does it have tilt steering?I would check the wiring in the steering column to start.
Why does my turn signal/ hazard light fuse keep blowing out
you have a short in one of the light sockets or a worn wire from the wiring harness. could be the flasher assembly. are the turn signals different bulbs from the brake lights? Does using the brakes blow the fuse? (Rear lights or brake light switch on brake pedal). left or right turn signal blowing the fuse will tell which side has the short. 4 ways only, replace the relay.
Turn signals on a 1995 lesabre keeps blowing fuses when I turn key on. I have lights everywhere else. need answers PLEASE
Have you unplugged the turn signal switch to see if the short is inside the switch or harness ?
I keep blowing a turn signal fuse on my 03 f350, why???
A mechanic would disconnect the turn signal switch and check the circuits for shorts to ground.
2answers
All turn signals on my jeep cheroke laredo are not working. Is the problem a bad fuse??
COULD BE BLOW FUSE.FAULTY TURN SIGNAL SWITCH OR FAULTY TURN SIGNAL FLASHERS WHICH IS LOCATED FUSE / RELAY BOX JUST LEFT OF THE STEERING COLUMN.
My turn signal fuse keeps blowing why?
I am thinking you might have a electrical short in your steering column
2006 f150 keeps blowing turn signal fuse
It sounds like the fuse is doing what it is supposed to do, and burning out when there is a short circuit. Check the wiring from the fuse block back to the lights and pay special attention to the trailer connection.
Turn signal flasher keeps blowing
This is more than likely caused by a Bad Turn Signal Switch Housing inside the Sterring column. The one that the Handle is attached to and Wraps around the Sterring Shaft on the Inside of the Column.
Top PIAA Optics Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a PIAA Optic Expert? Answer questions, earn points and help others
