PIAA 2008 Kia Amanti - All Amanti models - Xtreme White Bulbs Logo
j
joseph foytlin Posted on Apr 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Throttle position sensor
Symptoms of being bad
Vernon Taylor
Level 3:
  • Master 7,446 Answers
  • Posted on Apr 22, 2016
 Vernon Taylor
Master
Level 3:
Answers
7446
Questions
0
Helped
1960214
Points
26207
There isn't often any real symptoms that can be associated with a bad throttle position sensor because as soon as it becomes faulty it will trigger an obd fault, switch on the engine light and switch to the emergency running programme.
If you suspect it is faulty a code read is the first step and check the live data.
2003 sta fe hyundai give code 121
P0121 HYUNDAI - Throttle/Pedal Position Sensor/Switch 'A' Circuit Range/Performance
Possible causes - Faulty throttle position sensor - Throttle position sensor harness is open or shorted - Throttle position sensor circuit poor electrical connection - Faulty Engine Control Module (ECM) What does this mean? When is the code detected? Malfunction is detected when an excessively low or high voltage from the sensor is sent to ECM. Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P0121 Hyundai Description The throttle position sensor (TPS) responds to the accelerator pedal movement. This sensor is a kind of potentiometer which transforms the throttle position into output voltage, and emits the voltage signal to the Engine Control Module (ECM). In addition, the sensor detects the opening and closing speed of the throttle valve and feeds the voltage signal to the ECM. Idle position of the throttle valve is determined by the ECM receiving the signal from the throttle position sensor. This sensor controls engine operation such as fuel cut. On the other hand, the Wide open and closed throttle position switch, which is built into the throttle position sensor unit, is not used for engine control.
2answers
Po 122 problem light on had changed sensor problem not fixed trans not shifting right horrible jurks when it shifts.
P0122 is TPS signal low, which could mean you have a bad TPS, or a fault in the wiring or connector. I suspect a bad Throttle Position Sensor.
WHAT DOES P0123 MEAN?
SYMPTOM
P0123-THROTTLE POSITION SENSOR VOLTAGE HIGH
WHEN MONITORED
With the ignition ON and battery voltage above 10.4 volts .
SET CONDITION
Throttle Position Sensor voltage at the PCM goes above 4.5 volts for 3.2 seconds .
POSSIBLE CAUSES
  • Clock spring shorted
  • Throttle position sensor sweep
  • Intermittent condition
  • Throttle position sensor signal circuit shorted to 5 volt supply circuit
  • Throttle position sensor signal circuit shorted to battery voltage
  • Throttle position sensor internal failure
  • Sensor ground circuit open
  • Throttle position sensor signal circuit open
  • PCM
hope this helps, Tim 423 327 4108
4helpful
3answers
P0121 generic throttle/pedal position sensor a circuit range/ performance
P0121 - Throttle Position Sensor/Switch A Circuit Range/Performance Problem
The Throttle position sensor is a potentiometer that measures the amount of throttle opening. As the throttle is opened, the reading (measured in volts) goes up. The powertrain control module (PCM) supplies a 5 Volt reference signal to the throttle position sensor (TPS) and usually a ground also. A general measurement is: at idle = .5 Volts; full throttle = 4.5 Volts. If the PCM detects that the throttle angle is greater or less than it should be for a specific RPM, it will set this code.
Potential Symptoms: Symptoms of a P0121 trouble code could include:
Malfunction Indicator Lamp (MIL) illumination (Check Engine Light or Service Engine Soon light)
Intermittent stumble on acceleration or deceleration
Blows black smoke on acceleration
No start
Causes: A code P0121 may mean that one or more of the following has happened:
TPS has intermittent open or short internally
Harness is rubbing and causing an open or short in the wiring
Bad connection at the TPS
Bad PCM (less likely)
Water or corrosion in connector or sensor
Possible Solutions:
1. If you have access to a scan tool, see what the idle and WOT (wide open throttle) readings are for the TPS. Check if they're close to the specifications mentioned above. If not, then replace the TPS and re-check.
2. Check for an intermittent open or short in the TPS signal. To do that, you can't use a scan tool. You'll need an oscilliscope. The reason is because scan tools take samplings of many different readings over just one or two data lines and can miss an intermittent drop out. Hook up your oscilliscope and watch the signal. It should sweep up and down smoothly with no drop outs or spikes.
3. If no problems were noticed, perform a wiggle test. Do this by wiggling the connector and harness while watching the pattern. Does it drop out? If so, replace TPS and re-check.
4. If you have no TPS signal, check for 5 Volt reference at the connector. If it's present, check the ground circuit for open or shorts.
5. Make sure the signal circuit isn't 12V. It should never have battery voltage. If it does, trace circuit for short to voltage and repair.
6. Look for any water in the connector and replace TPS as necessary.
Other TPS sensor and circuit related DTCs: P0120, P0122, P0123, P0124
2answers
What is the symptoms of a bad throttle position senser on a 2004 mercury mountaineer
Several conditions could show DTC Throttle Position Sensor
Check this link to know additional details: manual/04/21j6674h/cip0120.
Keep us updated, hope helps.
Machine is throwing a MAF sensor i am told my doesnot have one, doing research on my own. the symptoms match a throttle position sensor.
the grand vitara maf sensor is usually located in the intake air duct, from air filter to throttle body. mounted on the intake manifold. some maf sensors are mounted directly to throttle body. symtoms of a bad tps are---it will cause tranny shift issues, bucking, jerking, idle surging, engine cut off, hesitation on take off, surge while cruising down highway. have a good day !!
8helpful
My 2003 chevy truck goes into limp mode and pulls code PO220.Where is the tps sensor located?
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- No throttle response Possible Causes - Harness or connector (The TP sensor circuit is open or shorted.)
- Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP) P0220 Description Electric Throttle Control Actuator consists of throttle control motor, throttle position (TP)sensor, etc. The throttle position sensor responds to the throttle valve movement.
The throttle position sensor has the two sensors. These sensors are a kind of potentiometers which transform the throttle valve position into output voltage, and emit the voltage signal to the ECM. In addition, these sensors detect the opening and closing speed of the throttle valve and feed the voltage signals to the ECM. The ECM judges the current opening angle of the throttle valve from these signals and the ECM controls the throttle control motor to make the throttle valve opening angle properly in response to driving condition.
When is the code detected? An unexpected voltage from the TP sensor is sent to ECM.
HAD MY ALTERNATOR REPLACED AND NOW ENGINE IS REVVING HIGH WHEN STARTED AND ALSO WHEN DRIVING.
Common problem of this type of symptom in Chrysler products is a bad throttle position sensor. I just replaced the one in my '03 Jeep GC for the same symptom.
Top PIAA Optics Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a PIAA Optic Expert? Answer questions, earn points and help others
