Panasonic KX-T7730 Corded Phone Logo
C
Charlie Tewson Posted on Jun 09, 2015
How do I program the Flexible Outside (CO) Line Buttons? The manual doesn't say!
I've been trying for weeks to add some different outside numbers to the CO line buttons. Some are already programmed which work perfectly, and dial out when I press them. I've been going into program mode, but beyond there I haven't managed to save a number so that it automatically dials out. How do I do this? Any help would be gratefully received!
Mohamad yasin
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 10, 2015
Mohamad yasin
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
7926
Points
10
If you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Testimonial: "Thank you so much - you saved me from a lot of frustration!"
Antonio Escojeda
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 27, 2016
Antonio Escojeda
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2782
Points
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
2helpful
How do i program my flexible buttons on my kx dt321 so i can see when other extns are busy?
Press PROGRAM press BUTTON press (0 to set a line button, press 1 to set an extension, press 2 for a outside number) Enter the number (line number or extension number or 9 followed by outside number) Press STORE
5helpful
2answers
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
    So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
    Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
    Which is yours?
    Carl
    Trying to get phone numbers programmed on a Panasonic KX-T7633. I can store them in a directory, but am having trouble assigning them to the "Flexible CO buttons".
    It's a trick. Assign the button, then press PROG the button, and dial 2 then 9, or whatever your access code is for an outside line, then the number and ENTER. You can press more buttons and dial more numbers, or press EXIT to quit.
    Carl
    How can i use the buttons of panasonic kx-t7730 corded phone ?
    The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
    The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
    Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
    Carl
    1helpful
    Hello, I have 4 Panasonic KX-T7630 with TDA100, and I set the flexible button for CO or INT, but the LED on the buttons didn't light when I receive a call. I can make a call use this buttons, but the LED...
    Whenyou program the buttons use the following steps -
    press PROG
    press the BUTTON to store
    press 1 for an extension and the enter the extn no. followed by STORE
    (or press 0 to store a line key)
    (or 2 to dial an outside number dont forget a 9 for outside line access)
    2helpful
    3answers
    HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Carl
    8helpful
    Programing outside (CO) line button
    press program button then press the flexible where you want program the CO line then press 0, here u can select which CO line need to be program.
    Ali
    Clear speed dial/one touch settings
    There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
    Top Panasonic Lands Phones Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
