I fixed my machine with this error by doing the following.
You need a T8 torx screwdriver and a thin flat blade srewdriver plus a replacement CR2032 button cell. Ensure that the S9 is disconnected from its power adapter. First pry up on the setting rotary knob at the top of the S9 and remove. Next remove the T8 torx screw from the bottom corner of the machine. There are then four slots located on two of the sides. Insert the flat blade screwdriver into one of the slots and gently push inward to unlatch that finger while also lifting/prying up the bottom cover. You should then be able to work your way around to each of the fingers and lift the bottom cover off. This then exposes the circuit board. There are two more T8 torx screws holding the circuit board in place. Remove them and carefully lift the board slightly. You can then see the button cell in it's holder at the corner which can now be removed and replaced with the new CR2032. The S9 can now be reassembled in the reverse order. Once reassembled, connect the power adapter but do not power on yet or you'll get the same error message as before. Hold down the power button and then while still holding it down power up the machine. Good luck, hope this helps.
Remove the SD card and power off and on with the card still removed from the machine. It probably won't help, but it's worth a try.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
