In order to get to the page you need to port forward you need to know your default gateway.
Usually:
192.168.0.1
192.168.1.1
192.168.2.1
Enter those into your web browser, if nothing comes up then go to Start. Then click run(or search if you have vista) type "cmd" then type in ipconfig
Start>Run>Cmd>Ipconfig
There is where you can see your default gateway. Enter that into you browser. I t might ask for a password, it's usually admin.
Also a lot of the port forwarding issues are due to your firewall settings. Make sure you add the ports to there as well.
What make and model router are you using? What port do you want to forward? What are your source and destination restrictions for the forwarding rule?
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074. Go ahead and enter the settings shown above into the Port Range Forward menu.
port forward the following ports up above to the ip address that you set your xbox 360 to.
I AM USING HUAWEI ETS1201 FIXED WIRELESS TERMINAL
I WANT TO FORWARD A PORT FOR UTORRENT.
I DONT KNOW ABOUT RESTRICTIONS FOR THE FORWARDING RULE
WHEN I TYPE THE DEFAULT GATEWAY THE BROWSER SHOWS THAT CONNECTION WAS RESET. BUT I AM ABLE TO BROWSE ALL OTHER WEB PAGES.EVEN WHEN I RECONNECT IT. AND MY DEFAULT GATEWAY KEEPS CHANGING EVERY TIME I CONNECT.
