usually from the factory the password is admin and the user admin ..but you may need to let them free..if it was used before and now you do not know the log-in ..just reset it using the reset button and will get to the factory settings ..My advice is to read the manual cause the password is mentioned in there is it is different ..
There is NO way of resetiing the device. You need to get hold of the factory reset device program from alvarion. This allows you to connect to the device and run a small program into which you enter the MAC address of the unit. The software then sets the unit back to factory defaults. You will need to run this program by connecting a cat 5 cable to each of the units you wish to reset and entering the MAC address listed on the device.
Cheers - Chris (Ex trainer of Alvarion Installation engineers)
First RESET your router to defaults. for that press RESET button for 10 seconds RESET button is in back side of router. Then connect your router to computer with ethernet cable. Then you can access it with following link. http://192.168.1.1 or http://192.168.0.1 type user as "admin" and password as "admin" or blank or "password" Then you can see configuration page of router. Set WAN settings as your internet service provider settings. Enable DHCP . CLick on wireless and enable wi fi. If you want secure router then enable WEP security then add new code it is your password key for connect wi fi. Let me know if you need further assistance. Thanks.
Many DSL modems need to be set into a 'bridged mode' when connected to a router. A call to Verizon customer tech support should be able to walk you through it as long as they supplied the modem. If not, and you do not have any documentation from your modem, go to the manufacturer's website and I am sure they will have a step by step. I hope that helps.
