20 Most Recent
Alvarion BreezeNET AP-10 PRO.11 Questions & Answers
I have IDU model ACPS-101G
Not sure off hand. You can find it by opening up command prompt on your computer.
- For xp, click start, then run on the right, in the run window type: cmd
- click ok
- for vista or windows 7, click start, programs or all programs, accessories, command prompt
- this will bring up you dos screen
- type: ipconfig
- hit enter (you can only type in one place)
- This will bring up your ip configuration
- Find default gateway in this list
- This is the default manufacture ip address to access the router.
- Your router must be connected to find this,
- wired ip is under ethernet adapter
- connected wireless is under wireless adapter subheading
hope this is what you were looking for. any problems let me know. Owen
7/10/2010 10:26:31 PM •
Alvarion...
Answered
on Jul 10, 2010
I want to make the wireless network private
Yes its possible.
If you set the password then only authorized person can access your wireless network.
Go to OPTION-set the password there.please remember that password
1/4/2010 10:10:36 AM •
Alvarion...
Answered
on Jan 04, 2010
I need to break password, to change IP address
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
11/6/2009 11:10:28 AM •
Alvarion...
Answered
on Nov 06, 2009
Configuring an alvarion router
well your asking a lot out of this. you need the software that came with it it tells you how to run it and ect... if you lost it look it up online for the software.
6/8/2009 2:48:22 PM •
Alvarion...
Answered
on Jun 08, 2009
I have a breeze access
Use t
his page for some detail on your Acces point
To connect to it use a lan cable and find Gateway IP address in your IPCONFIG command in Start, Run, CMD (click ok and use command screen)
1/31/2009 4:48:12 PM •
Alvarion...
Answered
on Jan 31, 2009
Work bridge alvaion pro 11
Have you considered contacting Alvarion directly?
If this is a revenue producing venture I would be contacting them. It could be the box itself, bad antenna connections, or simply a firmware issue. Seems like you have tried all the normal fixes.
http://www.neotel.com.mk/support.htm
Let us know how it goes. Anyone else with a suggestion, jump in.
9/11/2007 3:05:06 PM •
Alvarion...
Answered
on Sep 11, 2007
How to block the neighbors from using my wifi account?
you need to set up wifi security, which has its own password that you provide. Its easy to do if you have basic IT skills, and will be in your documentation. If you arent familiar the support desk of the modem supplier may help
8/30/2014 1:50:16 PM •
Alvarion...
Answered
on Aug 30, 2014
