The blinking light usually means the battery is dead and can't power on the laptop. If the charger is bad and won't charge the battery you will have that type of error. Get a multitester and check the voltage coming from the ac adapter. Put the meter on voltage, now put the red lead on the center pin and the black lead to the outside metal contact. You should get a reading of 18 to about 26 volts. My guess is the adapter has a short and can't power the unit. You should be able to get a replacement adapter from Ebay.com
I hope my solution works, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Try to reseat the memory module , get a screw and then reseat the memory then try to use a power adapter only if it power on the system good the adapter is working then try to use the batery only if it does not work your battery might had the problem .
Ernz.
