I need to know how to clean my lens on my xdvd 8181 dual indash dvd player it takes cd's and dvd's in but wont play them just says bad disk the disk are not bad i bought a brand new disk and said it was bad how do i fix this please help
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
you can try rocking the disk up and down a little it may go in. mines work up into this morning it take the cd/dvd but kick it out and display bad disk. no one has a aswer tor this one.
When you burn the c.d. make sure the burner has it on the correct settings. The "blank" c.d.s you are playing will play on a computer but nothing else. If you change the recording settings so that it isn't for cpu only you will be good to go!
Hey guys I have a xdvd-8181 indash dual radio and the password screen comes up and i forgot the password that i set it up with so i was wondering if there is any way to reset it??? Any help will be appreciated thanks Anthony
Take and bench test it. Pioneer brand do that when the ribbon cable is cracked. It is the one that get drag in and out during open and close. Open it up and check that. Goodluck.
