Tracfone Wireless LG 440G Logo
A
Anonymous Posted on Feb 24, 2015
How do I program 911 into phone?
Need to program 911 for elderly parent. When I entered 911 into Contact List, I received the error message "Invalid Number." Thank you for any help.
CHAD LAHTI
Level 3:
Master:
  • Master 193 Answers
  • Posted on Feb 24, 2015
CHAD LAHTI
Master
Level 3:
Master:
Answers
193
Questions
Helped
59803
Points
6012
Greetings
I use a tracfone and I can use 911..just tried it. I would contact the emergency NON number to see if they have a pre fix you can use.
Hope that helps
Chadman
I have an elderly parent that keeps dialing the emergency number by mistake when he has no signal and the Emergency number is the only option. Is there a way to block that?
PDF]Anonymous Call Rejection Automatic Busy Redial ... - HTC
www.htcinc.net/.../Calling_Feature_Instruc...
Horry Telephone CooperativeDial "*87". 3. Listen for confirmation tone, hang up. Automatic Busy Redial. Available ...There's no need to run to answer a ringing phone ever again! ... number will not be announced if the caller chose to block the delivery of his phone number. ... may onlyreceive calls from the number that you have forwarded your calls to.
Is there a way to completely disable the dialer including ...
android.stackexchange.com/.../is-there-a-way-to-completely-disable-the-...
Mar 26, 2014 - The phone has no service, but can still make Emergency calls and I'm ... you can dial 911 in a country where the landline emergency number is 11 .... The SIM card is just a memory chip, containing authentication information. ... the SIM card, the phone will request access to the strongest signal available, ...
Dec 28, 2015 • Cell Phones
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
tip
How to Unlock Cellular Phones for Free
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unlocking your phone free contains simple steps which are as follows:
  • Download Nokia Free Unlock Codes Calculator to the computer. Double-click on the downloaded file to install the program.
  • Double-click on the installed program. A window should pop up with several options. Choose the make of your phone from the list given. Choose the model number.
  • Press *#06# on your cell phone. Press "OK". A number should be displayed on screen. This is the serial number of your phone, also known as an IMEI number. Enter this number in the IMEI field in the Nokia Free Unlock Codes Calculator window.
  • Select your country from the list in the "Country" field. Select the name of your cell phone network from the list given. Press "CALCULATE". A list of unlock codes should be displayed in the window.
  • Replace the SIM in the locked phone with the one that will not work. Turn on your phone. A message indicating "Invalid SIM" should be displayed. Enter one of the unlock codes and press "OK". Your cell phone should be unlocked by now.
    Good Luck and Cheers. :)
on Dec 14, 2009 • Cell Phones
tip
Goodluck :)
on Dec 12, 2009 • Cell Phones
1helpful
Cant make a call to other pc
To place a free PC-to-PC call to another Yahoo! Messenger customer, you have a choice of three methods:
Method 1: If you wish to call someone on your Messenger List:
  1. Roll your mouse over the contact's name.
  2. Click the Phone icon that appears to the right of their name, then you'll hear a phone ringing.
  3. When you're done talking, click Hang Up for Yahoo! Messenger 8 and End Call for Yahoo! Messenger 9.
Method 2: Using the "Actions" menu to use "Call Computer":
  1. Click the Actions menu and select Call Computer.
  2. The "Call Computer" dialog box will appear, choose the appropriate tab:
    • For contacts on your Messenger List, click the My Contacts tab and then select the contact's name.
    • For someone not on your Messenger List, click the Other Contact tab and then enter the contact'sYahoo! ID.
  3. Click OK, then you'll hear a phone ringing.
  4. When you're done talking, click Hang Up for Yahoo! Messenger 8 and End Call for Yahoo! Messenger 9.
Method 3: During an instant message conversation:
  1. Start an instant message conversation with someone.
  2. Click the Call button in the toolbar of your IM window, then you'll hear a phone ringing.
Important: No 911 or other emergency calling services are available on Yahoo! Messenger at this time.
Please inform anyone using your Yahoo! Messenger that 911 or other emergency calling services are not available, and that they must call 911 or other relevant emergency calling services through their traditional telephone or mobile carrier.
I have been trying to connect a canon printer to my elderly parents eel top. Drivers are installed and usb connected but pc cannot see the printer. Used windows xp printer wizard but could not see USB in...
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner it will solve ur problem
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
15helpful
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
6helpful
3answers
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Top Tracfone Wireless Cell Phones Experts
Ngoro
john h
Are you a Tracfone Wireless Cell Phone Expert? Answer questions, earn points and help others
