Hotpoint Ultima WF860 Front Load Washer Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
Anonymous
Level 2:
Scholar:
  • Expert 86 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
86
Questions
0
Helped
32047
Points
182
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
1helpful
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
4helpful
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
24helpful
2answers
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
2answers
2helpful
2answers
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
