Very likely it is the battery. Beeping means not enough power especially when transmitting. Try charging the battery again, try transmitting again and plan on new batteries. They "wear out" even when not in use.
Why is my Powerbolt 1000 unit beeping? To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If
the unit continues to beep, the powerboard needs to be replaced
(A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470
satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here: http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
I just caught mine in the act and the message was "BAD RECEPTION" - but it doesn't stay on the display very long, if you don't catch it right when it beeps, you'll miss it.
According to Midland's support staff, this happens if the radio goes for 10 days without a weekly test signal from NOAA. To stop the beeping, simply turn off the power switch on the right side of the radio for a few seconds (if yours has it), or unplug the radio and remove one battery, wait a few seconds, then plug it back in and reinstall the battery you removed. You won't lose your settings if you have to unplug it and remove a battery, but you will have to reset the clock.
This happened to me and the next time I beeped the horn the radio came back on. Then for a long time radio would only come on if you beeped the horn. Battery has since gone dead, when I jumped it the radio now works fine. I am convinced wires are crossed and radio still sucks juice from the batttery even when the car is off. Battery stays charged and starts car if you make sure radio is off before shutting car off for the night. Am taking it to the dealer a.s.a.p. So long story short see what happens when you beep the horn.
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
It is possible your radio is not programmed, or has a bad/old battery.
It is normal for the side buttons 1 and 2 to beep when depressed to indicate you turned the feature on/off. Each of these buttons has the ability to be programmed a long and a short press feature.
If your radio beeps when your press the PTT button, on any or all channels, it indicates a low or nearly dead battery. Check your battery date code to see if the battery needs replaced.
If your radio emits a long tone on a channel, that channel is not programmed to function.
If your radio beeps a single beep when you turn it on, this is normal.
Charge your radio completely overnight, with the radio turned off. See if this solves the problem. If not, try a new/different battery to see if it will solve the issue. If not, drop by your local dealer and let them look at the unit.
