20 Most Recent Midland LXT310 2-Way Radio Questions & Answers
Check the batteries? Old, new, upside down?
Midland LXT310... | Answered on Oct 02, 2016
empty channel? no frequency on that channelposition?
Midland LXT310... | Answered on May 05, 2015
Are you on the same channels? Are you on a repeater setting? What are your squelch settings?Are your batteries fully charged? Power is needed on transmit, not so much on receive
Midland LXT310... | Answered on Feb 22, 2015
Typically you can expect the AA batteries to last about 18 hours using the 5-5-90 rule. (5% of the time your are transmitting, 5% receiving, and 90% standby) If you transmit/receive more than this the time the radio would go would be shorter.
Best regards.
Midland LXT310... | Answered on Jun 06, 2014
Here you can download the manual for your radios. http://www.midlandradio.com/Resource_/OwnerManual/53/LXT410.pdf Hope this helps.
Midland LXT310... | Answered on Mar 20, 2014
From the Midland.com site. Just click the link.
LXT480
Midland LXT310... | Answered on Nov 25, 2013
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Midland LXT310... | Answered on Oct 18, 2013
I had problems removing mine also. 1st remove the clip. With the back of the radio facing you push down firmly with your thumb and slide it off. At 1st I didn't think mine removed but after some extra force I was able.
Midland LXT310... | Answered on Oct 17, 2013
Have you tried opening the battery compartment on the rear of the radio?.
Peter
Midland LXT310... | Answered on Mar 18, 2013
  • Hi, to turn the radio up or down just press the up or down arrow while in standby mode (listening) or while receiving. Let me know if you have any other questions.
  • Hope this helps.
Midland LXT310... | Answered on Nov 12, 2011
Midland LXT310 2-Way Radio Logo
42 questions posted
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Midland Radio Communications
Most Popular Question
oops misplaced manual
  • Radio Communications
