Computers & Internet Logo
A
Anonymous Posted on Feb 22, 2015
How do I find the current firmware version on my DMREX88EB
Ray Savellano
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Mar 11, 2015
Ray Savellano
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
58985
Points
727
Check with the manufacturer's website. The support links should have information regarding firmware upgrade. In some cases, if you login to the router UI there will be a link you can click to check for firmware upgrades.
1helpful
How can I update my Sanyo Tv,It is not a smart tv
Upgrade to newest version firmware on you device, sanyo tv custom firmware update you current version firmware to latest version, download newest firmware.
Download new release software and update firmware last version
  • Last update version: 02.01.2020
  • Country: All
  • Download Size: 134 MB
  • Language pack: English, Chinese
  • Version: 5.1.11
Download and update firmware for products: sanyo fwbp505f firmware update, sanyo blu ray firmware update, sanyo android tv firmware update, sanyo projector firmware update, sanyo fw55d25f firmware update.
tip
What is firmware version and How to check your firmware version?
A "Firmware" is the phone's operating system stored in internal Flash memory of the device (disk Z.
Manufacturers release new firmware versions containing bug fixes, improvements and - sometimes - offering new functions.
Firmware upgrade can only be made in authorized Nokia service centre (point).
To check your current firmware version simply type *#0000# on main Phone screen.
on May 25, 2010 • Cell Phones
How do i downgrade firmware on epson px720wd printer
Determine your current revision level then go to Epson and get a firmware version earlier than your current version. If Epson's software checks the revision level and will not allow you to downgrade then I would stop now.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Can I down load any thing to get a better wire less connnection, it worked in the beginning but not now any more i have a "AirPort Extreame" wire less router thanks Alex keller
The first choice for AirPort Extreme base stations in this instance is to look at the firmware. Generally, using the most recent firmware version is the preference, but in some cases actually going to an older version may increase stability. Launch the AirPort Extreme Admin Utility (in Applications/Utilities); then select the appropriate Base Station in the left-hand pane. The firmware version currently installed will appear on the right-hand side.
The current version is at least 5.7. However, many folks have corrected dropout issues with their AirPort Extremes by reverting to Version 5.5.1. This link will take you to the download page for 5.5.1. Download the file, and then use the Updater application to install it. A caution in this approach is that you may lose some features that perhaps you had been using, but the rate of success for this approach is significant. You can revert back to your current version (be sure to write it down before you change it) if you wish.
NOTE that you MUST be sure that you are working with the firmware for the AirPort Extreme, and NOT the firmware for the AirPort Express. They are not the same.
Hope that's helpful.
1helpful
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
1helpful
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
Graphics print with pink background
That is a firmware issue. You can go to Xerox.com and follow these procedures.
Print a Configuration Report and review the Engine Firmware Version section to determine the firmware version. See the Related Items below for additional information.
Firmware version 05.08.00 or higher can be installed to resolve the image quality problem. If necessary, upgrade the firmware version. See the Related Items below.
If the printer's firmware version is currently at 05.08.00, replace the Print Cartridge. See the Related Items below.
elem_1_spacer.gif Related Items:> Go ToMicrosoft Windows OS Firmware Update Version 05.08.00
> Go ToApple Macintosh OS Firmware Update Version 05.08.00
> See AlsoHow To Print the Configuration Report
> See AlsoHow To Replace the Print Cartridge
2answers
Can't see the folders after restarting SS400-e
If you check their website, you will find:
Upgrading from a previous version of the firmware (to version 1.4) is a “data destructive” process.
it is strongly recommended that you first backup your existing data to another system in your environment. It is also recommended that you understand your current configuration of users, groups and shares to be able to recreate this under the 1.4 firmware.
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
3helpful
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Grand Canyon Tech
Grand Canyon Tech
