2005 Ford Freestar Logo
A
Anonymous Posted on Feb 11, 2015
What does reset tire mean
Message light came on requesting to reset the tires, what does this mean?
Oscar Goldman
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 11, 2015
Oscar Goldman
Expert
Level 2:
New Friend:
Answers
60
Questions
Helped
17020
Points
254
That means that the tire pressure monitor has detected a pressure difference in in one of your tires...Inside each of your tires there is a monitor attached to the valve stem that sends a signal to an on board computer.....make sure that the pressure is correct in your tires, as listed on the sticker...usually located on the driver door or body of the car....check your owners manual as to the procedure to re set the monitor...
Joel C.
Level 2:
New Friend:
  • Expert 42 Answers
Joel C.
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
11860
Points
142
It's a sensor that goes off when your tire pressure is too low or too high. Check the air pressure.
1helpful
2answers
Reset tire pressure light on dash 2014 ford focus
use this link.
http://enginepartsdiagram.com/2007-2016-ford-focus-tire-pressure-tpms-sensor-light-reset/
2helpful
I have a buick lesabre 2000 nd my tire went flat the check tire pressure light came out.. So i went to buy a new tire nd change it. But the light is still there.. I tried to reset it how it says on the...
SWITCH IGNITION ON, REPEATEDLY PRESS GAGE INFO BUTTON UNTIL THE MESSAGE TIRE PRESSURE IS DISPLAYED IN THE MULTIFUNCTION DISPLAY, PRESS AND HOLD RESET BUTTON UNTIL THE MESSAGE TIRE PRESSURE RESET IS IN THE DISPLAYED IN THE MULTIFUNCTION DISPLAY,RELEASE THE RESET BUTTON THE MESSAGE TIRE PRESSURE NORMAL WILL BE DISPLAYED IN THE MULTIFUNCTION DISPLAY, AFTER RESETTING TPMS THE VECHICLE REQUIRE UP TO 30 MINUTES OF STRAIGHT LINE SMOOTH ROAD DRIVING IN EACH OF THE 3 SPEED RANGES 15 - 40 MPH - 40 - 70 MPH - 70 - 90 MPH. MAKE SURE ALL 4 TIRES HAS THE RIGHT AIR PRESSURE BEFORE RESETTING TIRE PRESSURE LIGHT.OR LIGHT WILL NOT TURN OFF IF ONE TIRE IS LOW.
1helpful
I have a 2003 Impala and the low tire pressure message is on the message center. I have tried turning the light switch on and off 3 times while the car is in the on position and I have tried pressing the...
Page 2-46 of your owners manual. If you don't have one you can get on online version from the chevrolet website. Just click the owners link at the top of the page.
TIRE MON (Tire Inflation Monitor Reset)
This feature allows you to reset the tire pressure monitor after checking all tire pressures. To clear the LOW TIRE PRESSURE light from the instrument panel cluster and reset the low tire pressure monitor do the following:
1. Scroll, using the SEEK/PSCAN up or down arrows, until TIRE MON appears on the display.
2. Press the PREV or NEXT button to enter the submenu. RESET will be displayed.
3. Press the TUNE/DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
The low tire pressure monitor is now reset.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
3helpful
2answers
The words tire reset keep on popping up on my dashboard. What does that mean, and how do I get rid of it? 2004 Ford Freestar.
With and without "Mesage Center" respectively (pretty sure)
With the engine on...
Push "Setup" button, until your driver display says something like "Press Reset for system check".
Then push Reset. The system check will start, rotating through a series of checks.
About the fifth or sixth check will be the tire pressure. The system will sound the tone (same one that starts w/the light) and It'll say something like "Check Tires Pressure" on that moment press and hold for 3 or 4 seconds Reset. When you release the Reset button It'll show "Hold Reset if tires are OK". While that's up, hold the Reset button. After 3 or 4 seconds, the tire warning light will blink 2 or 3 times and then will stop .You need to be ready for it, because you don't get very long to release.
How to reset the low tire pressure warning if the vehicle does not have the "Message Center"
Turn the ignition to the ON position,
depress and Trip/odometer button (located in the instrument cluster) until "TIRE RESET" or "CHECK TIRE AND RESET" is displayed in the odometer display window.
Once "TIRE RESET" or "CHECK TIRE AND RESET" is displayed, press and hold the button for three seconds.
The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
This information is in the Owners Manual
Hope it helps
2answers
How do I reset the tire sensor on my 2004 Ford
Most will reset when the air pressure in all the tires is close to the same pressure.
6helpful
2answers
My Ford Freestar Minivan is reading RESET TIRE where the milage should show. What do I do?
I believe that one of your tires is low on air causing the pressure monitor to kick in. Check all your tires to make sure the inflated to the proper PSI which will be located on one of the door jambs
Change engine il and tire pressure message how do i rest
Must have codes for check engine light cleared with scan tool. Check all tire pressures and road test up to 35 mph. Tire message should clear if low tire was problem. If light for tires remains then possible radio frequency sensor problem. Sensor replacement may be necessary. Sensors have alkaline non-serviceable batteries. If battery is dead sensor will have to be replaced.
7helpful
2005 ford freestar reset light on
Vehicles Without Message Center To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
3helpful
2answers
My '05 LeSabre warning light for check tire pressure came on. I checked all 4 tires and they each have 32# of pressure. How do I reset the monitor? No manual in the car. Thanks
make sure your spare is up to 32#'s pressure also , unless its one of the donut tires, turn ignition switch to on with engine off , press and hold GUAGE INFO button which is located to the left of the sterring column until TIRE PRESSURE messgage is displayed , press and hold RESET BUTTON for 5 seconds , TIRE PRESSURE RESET message should appear on display , release RESET button, a TIRE PRESSURE NORMAL message should appear on the display , after ressetting the Tire Pressure Monitor system it requires 30 minutes of straight driving to complete calibration process .
J5
20helpful
Tire reset on in ford freestar
Reset without message center:
To reset turn the ignition to the ON position, depress and Trip/odometer
button (located in the instrument cluster) until “TIRE RESET” or
“CHECK TIRE AND RESET” is displayed in the odometer display window.
Once “TIRE RESET” or “CHECK TIRE AND RESET” is displayed,
press and hold the button for three seconds. The low tire warning indicator light will flash three times
Reset with message center:
To reset turn the ignition to the ON position, press the set up button on
the message center until “SYSTEM CHECK” is displayed. Press the
RESET button until “HOLD RESET TO RELEARN” is displayed, continue to hold the button for three
seconds. The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
