You may have too many app open ... even after shutdown.
Double click the home button. The line at the bottom is all the open apps. Hold your finger on one of them until they wiggle with a "-" circle in the corner. Tap the circles to close them and open memory. Then try you Mail again.
First, I'm not a AMAZON Kindle Tech.
* If it is "Open" (unlocked) then charge it up using the micro USB slot.
* If you can turn it on and the main menu goes on. Swipe the "Padlock" icon to open. Then swipe from top to bottom to get the menu display (for Kindle fire), Paper white will need to press the mode button (only button on the face of pad)
* If this is still a registered device then the regular menu will pop up and you will need to access the device menu by swiping top of screen downward. Select "+More" which will pull up the "Settings" menu. Select "My Account". Select "Deregister" continue and set up your Amazon account.
* If you want to wipe everything and reset the kindle (as giving it away to someone else) then go to "Settings" menu and select "Device". Select "Reset to Factory Defaults" then follow instructions. This will wipe all data and your account info as well as emails, bank records, etc.
* Resetting the Kindle to factory will be the same as if you just bought it from the store. It will automatically go through the welcome screen and help you set up your kindle and give a short beginner's course.
Aloha, ukeboy57
Hi Julie
If by larger screen, you mean Zoomed screen, it could be that you have turned on zoom in Settings / Accessability.
Also.... the iPad is "booted up" all the time. Generally all you are doing is Waking the iPad from sleep or screen in sleep mode.
To ReBoot your iPad (worth doing every month or so) First quit all Apps by double clicking round button and individually swipe each open App upward to shut the App down. When all apps are turned off, Hold the Top button & Round Button in together for about 5-10 seconds. This will shut the iPad down completely. When all off, Press the top button in for about 5 seconds. You will see the Apple logo while it ReBoots. This usually fixes any minor glitches etc in the Apps. If a particular App is giving problems, you can hold your finger down on it till the X shows in the LH Top of its icon. Click this and it will be wiped off your iPad. Then re download it for free through the App Store and check to see if problem has gone.
You could try to reset the iPad. Press the home button and the on / off button together and hold them till the light goes out.about 5 seconds. Then the apple logo comes back and in within one minute the starts screen should reappear.
I hope it works, because I would hate it if your grandson had to turn over his piggy bank. (Joking)
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
You'll need to do a factory reset: 1. With the device off, press and hold Volume
Up and Power.
2. Release the Power button
when you see the logo, but continue to hold Volume Up until
the recovery screen appears.
3. Use the Volume buttons to navigate the menu
and select wipe data / factory reset. Press Home to
choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
If you're connected to WiFi, you can tap the link
for 'forgot password' and then an email will be sent to your email address.
If you're not connected to WiFi:
There are three options when selecting the option
to enter Parent Mode: Select Age Group; Parent Controls; Device Settings, select
Device Settings
Enter the password 1orEnt= The
password is case sensitive.
Once in the settings, you can turn on the WiFi.
Return to Kidz Mode and try to enter Parent mode, tap Forgot
Password.
If you don't receive the email, again enter
Device Settings, from the left select Apps, on
the right select ALL from the top bar.
Scroll down the right hand pane and select
Kidzstar Mode, from the right hand pane select Clear
Data.
Return to the idle screen and switch off the unit.
When you turn it on, you will need to set up a new
account with a different email address.
1.Create folders within your email program to store your emails. Make the folders appropriate for storing the emails you receive. For example, if you regularly receive emails from certain people, make a folder to store emails from each person. Make folders to store professional emails and personal emails, and make subfolders within each to further categorize and sort your emails.
2.Set your message rules to route your emails to your specific folders. Many email programs have different levels of junk email filtering. Choose a low or high setting based on the volume of junk mail you receive. Once you have created message rules and junk email filtering, the junk email will be easily noticed when it arrives in your main inbox. Your email program will also attempt to recognize junk mail and will send it to junk and spam folders.
3.Take a few moments each day to browse through your email folders to review the emails you receive. Important emails sometimes get routed to the wrong folders, and they can go unnoticed if you do not check your email folders regularly.
4.Open your spam or junk mail folder and make sure these folders do not contain any emails you wish to keep. If there are emails that are not junk, drag them to the inbox or another folder for storage. Depending on your email program, you also may highlight the email and find a "Not Junk" option to alert your program that this email does not belong in the spam folder. Once you are sure the folders contain only junk mail, highlight one email folder. Press "Control-A" to highlight all of the emails in the folder. After highlighting these emails, press the shift key at the same time that you press the "Delete" button. This will delete all of the emails without sending them to the deleted folder.
5.Manage your junk email filter by opening the "Options" in your email program. From here you can add "Safe Senders" or "Blocked Senders" to either list.
