This has been a off and on thing for couple weeks especially after games went down everywhere
There is a tiny switch above the volume on the side of the ipad mini and ipad. You will see a red dot thats off slide it and all the spund will return. You locked it off by mistake. So many people do not realize this.
I never knew that switch was there!! Thank you :-)
Wow, that worked! Never saw that switch before.
That switch is for lock rotation. It doesn't control sound at all. I don't see any other switch.
Thanks it works
SOURCE: Why does my new iPad get so hot when I play games on it?
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
I hope that helps you out!
SOURCE: I was using my Ipad playing games and the screen
It's a rare but known issue. A trip to the Apple store is in your future, I'm sorry to say.
SOURCE: where is the ipad mute button cant get any sound
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute.
Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
SOURCE: How can I improve the battery life of my new iPad? Please help!
Here are two articles that should help you:
http://howto.cnet.com/8301-11310_39-20088870-285/10-ways-to-improve-ipad-battery-life/
http://howto.wired.com/wiki/Improve_Your_iPad's_Battery_Life
Testimonial: "Thanks buddy!"
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
The solution worked for me. Duh, the switch on the iPad 1 immediately to the left of the volume control had been moved to the 'off' position. Moved it to the other side and the candy crush sounds returned. Many thanks
Thank you, that solved the problem. I never knew that switch was there.
Sound was working on Bluetooth speaker and earbuds, but not internal speaker. I forgot about the mute switch, how dumb I am.
