Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a indepenONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHE - 25373509-gdidvipt5nahjm0x11drq30d-3-8.jpg"/uploads/images/25373509-gdidvipt5nahjm0x11drq30d-3-8.jpg" alt="25373509-gdidvipt5nahjm0x11drq30d-3-8.jpg" class="h_mi" />
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
It is the infinite switch (burner switch) located in the console,.
