Washing Machines Logo
C
Clarence Irick Posted on Jan 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DR STAY ON WONT START
TO START IT WONT START
jeff5may32
Level 3:
  • Washing Mach... Master 1,258 Answers
  • Posted on Jan 04, 2015
jeff5may32
Level 3:
Answers
1258
Questions
0
Helped
375676
Points
5289
Try this and please click helpful.
Do you have any error codes showing up? To find a manual for this unit, google FRIGIDAIRE AFFINITY WASHER REPAIR MANUAL
most of these units have the same parts inside them.
Dr comes up wont start
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires)
you can inspect these relay connection visably by removing the front control panel
you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay
this is not a factory taught test.
its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is gone.
My dr 200 wont start when cold with full or half choke i jump start it and when it warms up the choke works fine....the mind boggles thanks guys
Are you giving it any throttle when you try to start it, yu shouldnt, keep throttel completely closed when using hte choke or you will flood the engine
Kick start on my 1990 suzuki dr 350 does not engage
Don't hold the lever in as you kick. It is designed to get you just past TDC on the compression stroke. Try this:
1. pull in decomp lever (it should stay down)
2. slowly move kick start down. STOP as soon as the decomp lever pops up.
3. return kick starter to the top of the stroke.
4. kick smoothly all the way to the bottom. (takes very little effort)
5. no start? return to step 1.
If it still problem try check the adjustment on the decomp lever. The lever should stay down until you rotate the engine with the kick start to just past TDC on the compression stroke.
http://i199.photobucket.com/albums/aa104/jcalis/decomp.jpg
DR 200 Dual Sport 07 model. Been sittin in garage for 2 yrs . FIRING BUT WONT START. Carb problem? where do I start ?
Replace all fluids including any hydraulic fluids.
Fit new spark plugs and strip down carburettor cleaning the jets especially the main jet. If corroded at all, replace the corroded jets.
No charge
Bike batteries only last about two years. How old is your battery? Assuming the battery is good, the connections could be bad, the charging system should be checked.
1helpful
2001 suzuki drz 400, spark seems good and fuel flows to the carb.wont stay idel or start with out the choke pulled out and as soon as i push the choke in it stalls
How old is your air filter, if more than 1000miles, try to change it first then check also fuel filter condition. Good?
2answers
The bike wont stay going
You can drive without filter for a while but you run the risk of getting junk in the carbs that can cause problems later.
Top Washing Machines Experts
john h
