Savin C2525 Yellow Developer Genuine Logo
A
Anonymous Posted on Oct 14, 2014
What is the expected image count on a Savin C2525 Color Drum?
Copy Quick Digital
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 26, 2014
Copy Quick Digital
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
16977
Points
40
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
SC672
do not know the language post in english
How do i stop my savin 2020 from printing a yellow streak on my color copies?
Sounds to me like either a faulty yellow toner cartridge (try replacing it) if the drum is integral with the toner this should clear it. Otherwise you may need to replace the yellow image drum.
Im getting magenta backround on all color copies. I replaced the drum and developer, this did not change the problem
I had the same issue. I removed all the drums and DV units, removed the transfer belt and open the manual infrrd door and pulled to fuser. I found huge piles of magenta tone all over the place. Cleaned it up, put it back together and runs like a champ
Restoring default setting on my savin c2525
in user tools, hold the # key and press either, system setting or copier settings
Savin c4540 printing blue stripes down the left side of page
Looks like the drum unit is going bad or the xerographic module depending on which on you have but both develop the image and transfer it to the page. Pull out the unit and see if there is any lines or damage on the drum module which will look like a brown sheet of film or be a small roll usually green or blue in color.
1helpful
I have a Savin Model C2824, great shape. I want to downsize can someone tell me what fair market value is?
Without specifics all I can do is give you a ballpark. I would say around $1,500.00 would be a fair price. I base that on the fact that whom ever buys the machine will have no waranty. If the machine is under a transferable maintenance contract then maybe you could go a bit higher. I sell nothing but off lease used color and black&white copiers for a living and have done so for 27 years. If your machine had a fresh refurb done on it then the price would be higher. Anyone who is looking at buying a used color copier/printer is going to be concerned with possibly having to replace expensive parts like imaging units, fusing units etc. Also if your machine has the fax option this will help the selling price. This is a good machine and as long as the meter counts are not to high the the price point I have given you should be pretty close.
Good Luck and Thank You for using Fixya.
WheatlandServices
2helpful
2answers
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Top Savin Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
