20 Most Recent Savin 9935DP Laser Printer Questions & Answers
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Savin 9935DP... • Answered on Mar 04, 2015
is it unplugged from the network. is there a link light ON beside the network cord. Press the Printer button on the control panel and be sure the ON LINE is selected. Look in your Printers and Faxes folder and see if Work Offline is selected.
Savin 9935DP... • Answered on Nov 12, 2013
have you tried another toner cartridge? eyo7 [email protected]
Savin 9935DP... • Answered on Apr 28, 2013
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Savin 9935DP... • Answered on Dec 04, 2011
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
Savin 9935DP... • Answered on Apr 13, 2010
check the door contacts and the contacts on the transfer unit these need to be clean also
Savin 9935DP... • Answered on Apr 06, 2010
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
[email protected]
Savin 9935DP... • Answered on Oct 19, 2009
You need to enter service mode and the # is SP 5-912-1 set this to 0 (to get in to service mode press in sequence clear modes 1 0 7 and hold red stop for 5 or so sec. At the top of the screen should be direct SP highlight this and press the 59121 and it will take you right there.-Carl
Savin 9935DP... • Answered on Jul 08, 2009
Hi There,
Go to this link...it is the same model, except listed as a Gestetner.
http://www.nrgcss.com/drivers/Page3.asp?Brand=gest&Vw=&Fltr=0&Ky=578808089&Usr=&Cat=3&Mdl=11&Drv=3127
Good Luck.
Steve C.
PS... Please Rate Me.
Savin 9935DP... • Answered on Feb 09, 2009
Hi There,
The max on that model is 50. You can take out the ones that you no longer use to make more space. That is the only way.
Thanks,
Steve C.
Please rate me....Thanks.
Savin 9935DP... • Answered on Jan 31, 2009
Hi There,
This error has to do with the laser unit. There is a special fix for it, and it needs to be done by a Ricoh Technician. The laser front right corner needs to be adjusted. For this one, you will have to place a service call.
This happened during the move.
Steve C.
Standard Interfaces of the printer are:
USB 2.0, and 10/100 BaseTX Ethernet.
You can buy an ethernet cable to connect the printer on a network or a USB cable to connect the printer directly to your PC.
Savin 9935DP... • Answered on Jan 17, 2009
You may have broken the add paper sensor or actuator.
Savin 9935DP... • Answered on Dec 15, 2008
28 questions posted
Top Savin Office Equipment & Supplies Experts
George Mclaughlin
NOEL
NOEL
Lawrence Oravetz
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Savin Office Equipment & Supplies
Most Popular Question
resetting photoconductor unit
  • Office Equipment & Supplies
