Main system control memory IC fault. Do a reset to this set and check. If it do not help you, contact any service technician to replace this IC. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Testimonial: "Thanks very much I'll give it a go."
SOURCE: my dvd player reverts back to the tv
How old is the TV? You can contact the manufacturer and find out if you are still under warranty. They can tell you what you can do if you are or are not under warranty and where you can send/take the unit for repair - if necessary. Your manufacturer's number is 1-877-337-3639. If you want to e-mail them, the web-address is: http://contact.haier.com/engdefault.asp (this will take you directly to the contact page of the website). They claim they will respond to e-mails within 2 days immediately. You can also give this information to ***********. I don't know what could be causing the problem you both are having, but there is a good possibility that the manufacturer will take care of this under warranty (fingers crossed). I hope that everything works out well for you both. Hope this helps...
SOURCE: My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
SOURCE: channel memory
Don't have solution, but have the same problem. My guess is the chip is not holding its state. That could be the chip itself, a cap that isn't holding a charge or an internal battery that lost its ability to keep the circuit live.
Upsetting to say the least. My TV won't remember my custom channel line-up either...
SOURCE: logik 32" TV when turned on the blue circle at
I have the sanme problem too! Did anyone find a solution? [email protected]
