Lowrance X125 Logo
m
mike mcardle Posted on Sep 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When puushing the buttons on x125 will not react try to set program can not page up or down can not get into programs it will not power down
Craig Vohwinkle
Level 2:
Scholar:
New Friend:
  • Expert 97 Answers
  • Posted on Oct 14, 2014
Craig Vohwinkle
Expert
Level 2:
Scholar:
New Friend:
Answers
97
Questions
Helped
38028
Points
215
Your system is a bit older and may be reaching the end of its life. PrI or to giving up hope try a hard restart.with the unit turned off press and hold both the zoom in and zoom out buttons.press and release the power button to turn the unit on while you continue to hold both zoom buttons release the zoom buttons when you see a prompt appear on the screen. If this has no effect repeat the process only holding in the zoom out and pages buttons. Lowrance flip flops back and forth on their button configuration for doing hard restarts and I can never keep them straight from unit to unit. Hope this helps.
Can you tell me the code for a Polaroid TV for SANSAI URC-L969 universal remote please.
First is a link to a codes page. Next is a description of programming the device. The code page strikes me a little confusing about the method so that is why I provide the description of programming. Polaroid TV Universal Remote Codes & Program Instructions - Universal Remote Codes
  1. Turn on your Polaroid TV.
  2. Press and hold the SET button on your SANSAI URC-L969 universal remote until the LED light turns on.
  3. Enter the 3-digit code for your device using the number buttons on your remote. If you don't know the code, try searching for it online or contact the manufacturer of your device.
  4. Release the SET button once you've entered the code.
  5. Test if your remote is working by pressing some buttons like volume up/down or channel up/down.
2answers
Scanner
Yo should save first the file into the hard drive , and then print. If you want to save faster , copy the text into the notepad.
Color ink problem
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start (c01827528.gif ), click All Programs , click the HP folder, and then click the icon for your HP printer (c02053172.gif ). The printer software opens.
  2. In the printer software, double-click Estimated Ink Levels . The Toolbox opens.
  3. Click the Estimated Ink Levels tab to display the estimated ink level of each cartridge. Figure 1: Estimated ink level indicator c02752297.gif Image: Estimated ink level indicator.
  4. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  5. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the printer Resetting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer.
    NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the rear of the printer. Figure 2: Disconnect the power cord from the rear of the printer c01869581.gif Image: Disconnect the power cord from the rear of the printer.
  3. Disconnect the USB cable from the rear of the printer. Figure 3: Disconnect the USB cable from the rear of the printer c01850063.gif Image: Disconnect the USB cable from the rear of the printer.
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 4: Reconnect the USB cable to the printer c01868577.gif Image: Reconnect the USB cable to the printer.
  6. Reconnect the power cord to the printer. Figure 5: Reconnect the power cord to the printer c01869582.gif Image: Reconnect the power cord to the printer.
  7. Press the Power button (c01602202.gif ) to turn on the printer.
  8. Try printing again.
Solution three: Restart the computer Restarting your computer might resolve the issue.
  1. Save the latest changes to your files, and then close all your open programs.
  2. Click Start , and then click Shut Down . A dialog box opens.
  3. Select Restart . Most computers turn off, and then turn on again automatically.
    NOTE: If a dialog box opens with a message that it is now ok to turn off the computer, press the power button on the computer to turn it off. Then press the power button again to turn it on. After a few minutes, the computer is ready to print again.
  4. Reopen the file that you want to print, and then try printing again.
Solution four: Check for blank pages in the print preview If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
  1. In most programs, click File , and then click Print Preview . If the program you are using does not have this option, consult the program manufacturer.
  2. Review the print preview for blank pages.
  • If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.
  • If the preview contains no blank pages, continue with the next solution.
Solution five: Check the USB cable If the printer connects with a USB cable, a faulty connection might cause the issue. Follow these instructions to check the USB cable.
  1. Make sure that the USB cable inserts all the way into its port on the rear of the printer. Use some pressure to push it in all the way. Figure 6: Insert a USB cable into the rear of the printer c01868577.gif Image: Insert a USB cable into the rear of the printer.
  2. Make sure that the USB cable inserts all the way into its port on the computer. Use some pressure to push it in all the way.
  3. If the issue persists, try replacing the USB cable with a known good cable.
Solution six: Check the printer settings on the computer Issues with the printer settings on the computer might cause the printer to print blank pages. Follow these steps to check the printer settings on the computer. Step one: Check the default paper settings Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)). Follow these steps to check the default paper settings.
  1. Click Start (c01827528.gif ).
  2. Click Printers and Faxes . The Printers and Faxes folder opens.
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . The Printing Preferences window opens.
  4. Click the Paper/Quality tab, and then compare the settings in the Paper Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Paper Size drop-down menu, change the setting:
    1. Click the Paper Size drop-down list, and then select the size of the paper that is in the tray.
    2. Click Apply to save the settings, and then click OK to close the Printing Preferences window.
Step two: Print a test page Follow these steps in the order presented to print a test page. A test page might help determine if the printer installation caused the problem.
  3. Right-click the printer icon (c01532298.gif ), and then click Properties . The Properties window opens.
  4. In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page. Figure 7: Example of Windows XP Printer Test Page c01532301.gif Image: Example of Windows XP Printer Test Page.
  • If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
  • If the page is blank, continue to the next solution.
Solution seven: Print from an alternate program Follow these steps to try printing from an alternate program, such as Microsoft Notepad or WordPad, to determine if the current program is causing the issue.
  1. Browse to the location of your saved document, right-click the file, and then click Open With . A window opens with a list of programs.
  2. Select a program other than the program you are currently using to print the document.
  3. Open the file in the program, and then check the contents.
    NOTE: Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense.
  4. Try to print the file:
    1. Click File , and then click Print . The Print window opens.
    2. Select your HP printer from the Select Printer drop-down menu, and then click OK .
    If successful, the printer prints exactly what displays in the program window.
    • If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.
    • If the document still prints blank pages in the alternate program, continue to the next solution.
    • here are a couple things you can try hope this helps you
I do not know how to turn off internet explorer in order to install adobe flash player
Observe the internet pages for the three buttons at top right corner. Click the last button at top of internet page that has X also knwn to close pages.
For example, the three symbols are miniature immetations of the internet page click buttons. _ & X
Click the following sign should minimise mometarilty the internet page. _
Click the following sign should exit the page entirely. X
Important notes
Several reasons require to exit the internet explorer to download another prorgam acquirable from the network. First the internet connectivity least has enough bandwidth to display both programs of browser and new program requsting download. Once the internet has allowed to locate and display the download page, simple click the exit button on the internet explorer page only. The page should exit retaining the download button. A click button on the download bar should allow the download to commence. Until the download program has been completed, the intermnet explorer pages should not be attemped to display by user else the download is haulted to currupted requring reinstallations. Once the anunterrupted download has been achieved, the messages button may request to power exit the entire network programs for the computer to reconfigure to discover the new settings. The computer some instances may require power shut down completely for the entire new features to take effect on the first start after download was attained.
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
I just bought a new kenwood tk272 G when i went to have it programmed with the frequencies i needed they could not get the page(which is just our tone) to work right it is on page but it will pick up our...
We are not familiar with your Kenwood model, yet we believe what you are experiencing is a programming issue. During programming (on Motorola equivalent radios) there should be a place where they choose how you want your pager to reacte in combination with the radio. Usually it is as simple as choosing "AND" or "AND/OR" in the signalling section of the programming. You might check back with your Kenwood dealer, or with another Kenwood dealer who is more knowledgeable on your particular model's paging feature.
125settings for language back to English on LexmarkX
To change the language on the LCD screen of the X125 printer, please follow the steps given below:
1. With the printer power on, press the "Setup" button.
2. Then press the "Menu" button until "Set Language" shows on the screen.
3. Press the "Options" button until you see "English."
4. Press the "Start" button once and let us know the results.
Program page not working in Windows Mobile on HTC Diamond
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
2answers
Lexmark X125
This is very unusal with All-in-one printers. Have you try Hard reset till? Keeping the power on button press for 10 sec till it get on..
Also is the error showing on display screen of printer or at PC? Which Os is running on your PC.
Please also try this --> Power off the printer then computer, Unplug the printer from PC and then main power board--> then restart PC --> after then shut down PC and then again attach printer to PC and power on.
Let me know about the printer spooling if showing any error in Printer setting window.
2answers
Power Button
Hi Monkeycdo,
There's a program that gives you the Windows XP shutdown window to turn the Axim off (http://classic.pocketgear.com/download.asp?product_id=6666)
the main page is: http://freewareppc.com/utilities/shutdownwindowsxpstyle.shtml
However, you can also adjust the power settings to turn the unit off after a certain time of inactivity.
If the power on is a problem, the power control settings have an option to "Turn on Device" if a program button is pressed. Check that option and in the future you can press the bottom buttons on the front and the unit should come on (you will have to close the program window that you requested when you pressed the button);
let me know how this works (grandgregojunk [at] yahoo.com) or if you have any questions.
Good luck,
Greg
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
