20 Most Recent Lowrance HDS 5 Fishfinder GPS Chart Plotter HDS 5 Base US 83 200kHz Questions & Answers
Hi, the best solution if possible is to run them off separate batteries. Regards Phil.
Lowrance HDS 5... | Answered on Aug 29, 2019
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Lowrance HDS 5... | Answered on Apr 25, 2016
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Lowrance HDS 5... | Answered on Feb 03, 2016
Hi Pieter
The problem here is that the unit has no idea where it is on the planet.
I think your best bet would be to reset the unit to factory defaults (page 11 of the owner's manual) and THEN use the setup wizard (page 6) to reinitialize the device.
Link to owner's manual provided below in case you or anyone else requires it.
Hope this helps and good luck!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Lowrance HDS 5... | Answered on Mar 08, 2015
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Lowrance HDS 5... | Answered on Feb 14, 2015
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
Lowrance HDS 5... | Answered on Dec 14, 2014
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
One of the settings is 180 degrees off. Go back through the manual and check all of your setup settings. I had that happen once to me.
Lowrance HDS 5... | Answered on Jan 03, 2014
most the time its a bad key pad when unit wont power on and what it cost to repair you can buy another one check the pins in the power cord see if there not broke or bent yes they break take a 12 volt test light see if you have power going to power in the plug that connects to back of unit if you have power . . .bad key pad
Lowrance HDS 5... | Answered on Dec 19, 2013
press menu and select return to vessel. Regards Phil.
Lowrance HDS 5... | Answered on Jun 28, 2012
Hi Toshio, I have the same unit and I am not aware of a sound period adjustment. The unit most likely needs a hard reset because of a software glitch. To do this hold down the zoom in and zoom out buttons while turning the unit on. Keep holding both zoom buttons until the start up screen is completely loaded. This procedure returns the unit to its factory settings and should solve your issue. Regards Phil.
Lowrance HDS 5... | Answered on Sep 27, 2011
Lowrance HDS 5 Fishfinder GPS Chart Plotter HDS 5 Base US 83 200kHz Logo
Popular Tags
45 questions posted
Top Lowrance Boating Experts
Ekse
Mike
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
fish finder shutsdown or restarts when
  • Boating
