Question about Lowrance Boating
Got a lowrance elite ti2,the screen freezes on the warning page.tried the reboot,did not work what is the fix,please.
Posted by Hughie Fequet on
Wally
    New Friend:
  • 28 Answers
Reset use a soft reboot. Or hard reset make sure you back up all your settings on fish finder with chip or home computer. OK guys so the first thing you wanna do when resetting your unit whether it's soft reset or hard reset we're gonna start with a soft reset which is gonna save any GPS data anything like that so we're gonna head over hold the Power & Page button press the power button we're going to go over and press power button but I'm at the unit but up until you see the warning screen where you have to except the depth on reset Can see we still have our Saved waypoints. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power switch to off then press and hold the plus minus key as well as the power key let go of the power key keep holding plus minus until the warning screen comes up in a hard reset your going to delete all data on this year it's gonna be like we just bought it went to the store and bought it and cam home with know data whatsoever no settings nothing OK I warning screen has came up we can let go of her buttons and press except start demo. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power so that our unit is off then press and hold the plus & minus key as well as the power key don't let go with the power key holder plus minus until the warning screen comes up and a hard reset is going to delete all data on this year it's gonna be like-you just bought it went to the store and bought it and brought it home no data whatsoever no settings nothing OK or warning screen has came up we can let go over buttons and press except start demo now. OK so now you should not see any saved data so that's how you do a hard reset and a self reset. Load your Data card and shut off the power key. Then turn back on and follow screen steps. This should fix you issues.
Walld"
Posted on Oct 02, 2019
1 Related Answer
zcomputerwiz
zcomputerwiz
  • 92 Answers
SOURCE: My lowrance elite 5 hdi won't go past the "elite
Make sure that your battery is fully charged. Try a hard reset if it still won't start up.
This will erase all user information on the device, so you will have to set it up again.
With the unit off, press and hold the zoom in (+) zoom out (-) and power buttons. Release the buttons when the map displays.
Article Details
Posted on Jul 19, 2014
HI my name is ED I need to get another Operation Manual Elite-7 combo HDI mine got all wet and stock together.
Do you mean the Lowrance Elite-7 HDI? Most Lowrance manuals are available here: http://www.lowrance.com/en-US/Support/Documents/ . Click on the Elite series and then scroll down the list in the Select Product window. Then look at the lower right side of the page. The Operation manual and installation guide are both available. The direct link to the operation manual is currently http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf .
I hope this helps.
Feb 23, 2017 | Boating
I bought a used boat with a lowrance Elite-4x HDI in May. It worked fine until just the other day it won't power up. I have 12V of power through the power cord to the connector.
Press & hold the + & - key while powering unit on, continue to hold the +/- keys until the unit boots up to warning screen. This don't do it, call support 800-628-4487 and talk to a tech as an "experienced technician". Best luck & good fishin!
Oct 29, 2016 | Lowrance Boating
How do you manually reset a lowrance eliite 5
You can try holding in the zoom in/out buttons (+/-) as you push and release the power button.
Hold the zoom keys until you hear a beep.
If your hard restart is successful. You should see the GPS screen with prompts for language etc.
if you cannot get the system to cooperate and all you see is the "Lowrance" screen, then you are experiencing a Castro pic system failure and the unit needs to go back to Lowrance.
Jun 21, 2015 | Lowrance Elite 5 Color SonarGPS Combo
How do I erase trails
http://www.lowrance.com/Global/Lowrance-images/backgrounds/lowrance_hds_background.jpg
Here is a link to the lowrance website to the elite 5 page where you can download a pdf file of your owners manual.
Go to your gps screen on your unit and press "menu" twice. Under the Chart heading you will find "waypoints, routes and trails" select this option and when you open it you will find a tab for trails this is where you will locate the options to delete your trails so they wont clutter your screen.
Dec 15, 2014 | Lowrance Elite 5 Color SonarGPS Combo
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Apr 11, 2009 | Lowrance XOG GPS Receiver
Boating Logo
468 people viewed this question
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
