NO SOUND OUT OF SUB WOOFERS I AM GETTING POWER TO THE AMP
the easiest thing to do is check the voltage at the amp, between the red power wire and the black it should be the same as the voltage across your battery under the hood. now turn your radio on and c heck the remote turn on wire this wire is at the amp and is usually blue it should have 12 volt when the radio is on and 0 volts whe the radio is turned off check between the blue remote wire and the black ground wire unhook subs from amp and check the resistance across the speaker terminals with a digital mutimeter, if your subs are 4 ohms then your reading on the meter should be around 4, if it is close to 1 or 0, then it's probibly your subs. if everything is good check the fuse on the amp
